DMT Aligner with Diamond plates and Polishing films
I'd really let my EDC get pretty dull... my bad. So last night I decided that it needed the full treatment.
I don't measure my angles any more, instead, when using the DMT Aligner just set it to it's lowest setting. Combined with my Benchmade 710 Axis-Lock, it's somewhere between 16-18 degrees... A bit shallow for a large-bladed folder, but I rarely do any heavy cutting with it, so that setting lasts a good long time when properly maintained with a strop.
I have five different diamond stones for the Aligner; Ex-coarse, Coarse, Fine, Ex-fine, and Ex-ex-fine. I loaded up a good movie on the screen, put the Ex-coarse stone in the holder, put a Sharpie mark on the edges, and went to work. Twenty minutes into the movie I switched to the next stone and re-applied the Sharpie, another 15 minutes, another stone, ten more minutes, another, and 5 minutes with the last stone. Then it was time for the polishing films. These need to be used edge-trailing, and with a bit more care, so I turned off the movie and paid attention to not losing my fingers.
I have films for 2,000 - 4,000 - 8,000 - 10,000 - and 15,000, and by wrapping them around the stone mounted in the holder, continued to hone the edge. I guess I spent about another 20 minutes using the 2,000 grit film, then quickly went through all the films, and then moved to a shell cordovan horsehide bench strop for another 5 minutes.
I'd post a picture of this knife but if you look at this edge, your eyeballs will bleed...
With regular stropping on bare horsehide, I probably won't need more for a couple of months. Then I'll start stropping on Chromium Oxide on cased cowhide (followed by bare horsehide) for a few more months. I shouldn't need stones again until maybe Christmas time...
This is one of the older Benchmade 710's, made from ATS34. I really like the way it holds an edge.
I reprofiled my Delica in ZDP-189 with my DMT Aligner progressing from XC thru EEF to strop in about 30 minutes total.
That's super fast. It usually takes me at least an hour or more to make it through the progression on a never sharpened knife. Of course, I go slow and make a pass deliberately.
Sent from my XT1080 using Tapatalk
I've done more or less the same thing with my Manix 2 M4 and my Manix 2 lightweight S110V. What takes me the longest is reprofiling a factory edge that is way off, even for a mundane steel.
Sharpening with the DMT Aligner can be very, very fast if you want it to be. But I was watching a movie at the same time for most of it, so not really paying attention to what I was doing until I got to the polishing films. That's one of the things I like about the DMT... It's almost 'automatic,' so if you are not in the mood for the Zen of Sharpening on good Japanese Waterstones on a Sunday Afternoon, the Aligner can get the job done just as well (or better) in 1/5 the time.
What kind of films are you using?
Just some generic films that I picked up in a Japanese Home Center. The Home Centers in Japan are really remarkable for what they sell... In this case, sheets about 10" sq for a few dollars, in all different grit sizes.
Stitchawl
