With this current setup I have I can achieve really good resells.. I can begin to shave off of the dmt coarse but it doesn't seem to cut paper too well without slicing.. read somewhere u can achieve push cutting paper with the coarse.. it seems to stay like this and only when I use the ceramic ultra fine it really begins to get scary sharp.. I use both sides of the knife while shaving to make sure there is no burr and take extra steps during each grit to remove burr but I don't understand why it has such a big change from extra fine dmt to ultra fine spyderco.. maybe it's normal? Maybe I don't fully remove the burr until then? Maybe it's nothing and it's perfectly normal I don't know just curious what results everyone else achieves off these stones. My dmts may not be fully broke in but I think they're getting close. It goes from barely shaving and slice cutting paper to push cutting newspaper and popping hair off no problem. Normal or problem somewhere?
Hi,
What are "extra steps" you use, double angle deburr?
No more than 1-2 light alternating edge leading passes?
Light as in under 100 grams, under 50 grams, as light as you can control?
After you double angle deburr do you do equal amount of passes at original not-double angle?
Light edge leading alternating passes? No more than 10?
Or after deburr ,
intentionally raise a smaller tiny tiny tiny burr with 30 passes per side original angle,
then deburr-2 at double andle and backsharpen-10 at original angle
What kind of held me back from doing 90-90-90 push cuts in the first ~year of 2015,
is discovering that I can be really really really really really really wobbly,
every pass range from 0 to 40 degrees,
so as long as I raise a giant burr, and then cut it off carefully,
it will shave, even if the edge is uneven....
even if I have to deburr 5-10 times ...
Eventually without changing what I'm doing ,
just by lowering the angles and widening the bevels,
the same kind of lots of wobble and I could do push cuts too,
and then I kept wondering,
well I can whittle beard hair and push cut
why can't I whittle head hair doing the same wobble dance?
well the burr is too big,
and with wobble the apex line isn't as consistent,
key is really raise only a tiny tiny tiny tiny tiny burr
and if it won't whittle head hair after deburr and backsharpen
then do fewer strokes and raise an even more tiny burr
and then it just kind of happens
You can see the technique here
Same 90 degree push cut off norton india fine ... its ~P400 /35micron
[video=youtube;EcrnigC3Anc]https://www.youtube.com/watch?v=EcrnigC3Anc[/video]
320 grit stone , push cut newspaper at 90 degree, 45 tip left , 45 tip up
Normark EKA 12C27 : optimal edge geometry for slicing hardwoods (norton economy fine edge) - CliffStamp
