First thread on here, I hope it is helpful and starts a good discussion.
I am not a knife maker, well, at least not yet. I have a bad habit of starting new habits. I have been reading here about steel and sharpening as I am a traditional woodworker and spend a lot of time on chisels, planes, hand saws, and some power tools like my jointer that have blades that need sharpening. I have tried carborundum, various arkansas, water stones, diamond stones, ceramic stones, and probably something I have forgotten along the way. Currently, I am using several DMT diamond plates (Diasharp) and the medium, fine, and super fine Spyderco bench stones.
I have also tried the scary sharp system which does not work for me. My biggest task is flattening the back of blades. I do the entire back and work until I have a good polish. I have many reasons. One that should interest all blade owners is that a polished blade, with no oil, wax, or other coating, repels water. And, that rust gets started by water or sweat sticking to a blade by adhering to the tiny scratch marks left from honing where polishing was not completed. Try this with one of your small blades and splash water on it. Clean it off with alcohol and splash water on it again. If you have never run this test, you will probably think there is oil or wax on the blade. The water beads up and runs off.
Scary sharp probably works ok for knives or very small blades. On large plane blades, the inconsistent surface of the sand paper shows up in the final results. You can go back and forth indefinitely and get slightly different results each time. For me, the only thing that works really well is a flat, stable, stone surface.
First, carborundum. I have several. These are the very affordable grey stones with a course and medium side. They can be used with water or oil. Carborundum is very hard. It will sharpen almost anything. It is a little soft for carbide. But, it is good on just about anything else. I have a dozen or so carborundum stones. I use them on axes, lawn mower blades, restoration of very old steel, and for flattening other stones. Carborundum stones wear away as you sharpen. This means you get new abrasives as you go, and you have to be careful to not loose flatness too much between lappings.
I have numerous arkansas stones. I like them. They work well with water and oil. (BTW, try baby oil for your sharpening oil. It is cheap, thin, and high quality.) They are a little slow and the range of sharpening action is limited. There, I just made up a term. I like sharpening action because grit density, grit size, etc., are very misleading. That is a very long discussion and I will not bore you with that now. If you are used to synthetic stones, you will probably not like the inconsistency. All of the hard, steel cutting abrasives in the stone are not exactly the same size. The surgical black and the white get very close to consistent grit. But, it is a natural stone. Arkansas stones also wear away as you sharpen.
I have many water stones. I do not use them. That is a long discussion and you probably know more about them that I. My problem is the wearing that generates sharpening speed, and quickly turn disastrous while trying to flatten the back of a blade. It can be done, but it is just not for me.
