To you super knowledgeable sharpeners!
Could I go from my DMT Diasharp Extra Fine (1200grit) straight to a Spyderco Ultra Fine Benchstone (?? grit) with out too much issue?
Thanks
You can do it, but I have both of these stones (as well as a DMT EEF) and you will not erase the scratch pattern from the DMT EF going straight to the Spyderco UF. The micro ratings are similar, but the diamonds definitely leave a coarser finish. This really only matters if you're looking for polish.
The EEF is only offered on a few of their product lines. 8" Dia-sharp is one, Dia-fold is another. There are a couple more. So it's easy to overlook them if you are looking at the other product lines.Just realized you said DMT EEF. Was not aware of an EEF...
Here's the URL with the search for "EE" which is what they call it. It highlights the five products offered in that mesh:
https://www.dmtsharp.com/search/?search_query=EE
DMT lists it as "8000 mesh, 3 micron"
If you are looking for the Spyderco UF finish, I would personally go DMT EF -> Spyderco Fine (just to change the scratch pattern, they are about equivalent "grit") -> Spyderco UF, based on what you have.
I don't have the UF Spydie or EEF DMT, but I do have the EF and Spydie Fine, so when I am using those in a progression, I go DMT EF -> Spyderco Fine -> strop on balsa with 1u diamond or hard leather with green chromium oxide paste, depending on the steel (diamond strop for harder steels, Cr2O3 for the softer ones).
Edit: I am not a super knowledgeable sharpener, I just sharpen for my own needs. I don't try for ultra-mirror finish edges, just ones that cut what I need to. They can usually cut phone book paper cleanly and shave arm hair when I am done, but I am not going for anything extreme. On many knives I don't go further than a hard Arkansas or a 2000 water stone before stropping. So keep that in mind before you rely too much on my advice.
