DMT Diasharp, Smooth Out Over Time?
I'm looking to invest in some good benchstones to get back in to hand sharpening. I used the DMT stones with holes in them before and they worked well, but they seemed to lose a lot of grit over time. Do the Diasharps do this as well?
What benchstones are good to get in to right now?
Diamond hones will slough off some grit with use. BUT, they can last almost indefinitely with some care. Using them with some sort of lubrication like water, or water + dish detergent, or mineral oil helps. Using light pressure, and 'letting the grit do the work' is most important of all. They'll shed a lot of abrasive if used dry and with too much pressure; it rips the diamond out of the nickel substrate. If one feels the need to lean into the hone a bit with more pressure, in order to make it work faster, chances are a coarser grit is needed.
Depending on the steels you're sharpening, you may not need diamond anyway. If so, silicon carbide and/or aluminum oxide stones (think of Norton's Crystolon and India stones) are probably the next-best alternative to a diamond hone. Some very wear-resistant steels like S30V/90V/110V and others with large amounts of vanadium carbides will usually need diamond for re-bevelling and other heavy grinding jobs done by hand, without powered tools like belt grinders or wheels.
David
I use a little detergent in the water I use with my Edge Pro so I can do the same with these. I went ahead and got the Duosharp coarse/fine in an 8" stone that comes with the holder (hard to beat for $60 or so). I'll start with this and see how it does. I don't have much in the way of high wear-resistant steels. Most of mine are 1095 and other high-carbon steels, as well as stainless steels like 154CM and M390, etc. Pretty easy to sharpen.
Thanks!
my experience with DMT & EZ-lap are that the diamond hones cut at least one grade coarser when new, then pretty much true to advertised grit once they're broken in.
I prefer the "solid" surface hones to the interrupted surface styles because they seem to do more work faster.
This can't be stressed enough. I have a couple of 4" Diasharps that I use with my KME system. I just let the weight of the rod, clamp, and stone rest on the blade and move them back and forth. I use no hand pressure whatsoever. :thumbup: And, yes, I can also confirm that they will smooth out a bit once they get worn in. They still cut just fine.
edit: I also use them with water. I sharpen at the kitchen counter and just run them under the tap every so often as I sharpen.
I haven't noticed any reduction in cutting efficiency of my DMT hones over nearly two decades. I hone dry, and once in a while wipe them down with BreakFree CLP.
