Hi Guys,
I just came back from a summer road trip and faced a sharpening conundrum. When I take a car trip, I often sharpen the kitchen knives at the homes I visit. Because sharp knives are a dark art known only to a few, the blades I encounter are often badly abused, requiring significant metal removal to reestablish an edge. For this I take a set of DMT Duofolds, which have different grits on opposite sides, along with a 204 Sharpmaker. The Duofold with the x-coarse/coarse grits gets the main use. I thought I was being careful not to press too hard, letting the tool do the work, but the x-coarse side has worn itself smooth after reprofiling about 15 kitchen knives. Is this to be expected?
I was surprised because I own a coarse DMT 8" by 3" plate that I have used for years and it still cuts well after hundreds of sharpening jobs, including reprofiling chipped chisels. I also own a double sided DMT benchstone that is the kind with holes on a plastic billet, and this seems to have worn much faster than the continuous plate on the thick steel backing has. Are the heavy diamond plates that superior to the ones with holes over plastic, or is my technique with the Duofold somehow wrong? Typically I use the Duofold by swinging it along the blade freehand, much like how a stone on a jigged system is used. This seems to give a good result rapidly, and requires not a lot of force to remove the steel from the bevels.
This failure occurred before I had finished all the knives in the last house, so I bought a gray Coghlan's pocket stone at a local hardware store (only one in that town!) and glued it to a wooden paddle. This setup worked nicely to reprofile the remaining knives. I used it dry and when it glazed over I opened the surface back up by rinsing it under running water with a Scotch-Brite pad. The wet stone then worked a nice slurry on the hatchet I was improving, just like a water stone.
I love the lightweight, compact nature of the Duofolds, and am disappointed in the lack of durability. I want a rapid removal abrasive that is portable for the road, and am open to suggestions. My homemade paddle stone was inexpensive and pretty good. I wish I knew what the abrasive on it is. The website says it is "electric furnace abrasive grain." link:http://www.coghlanscampinggear.com/coknshst.html
I look forward to your suggestions.
Bill
Bill
