- Nov 24, 2005
I have a USMC Ka-Bar that came new with a crappy edge. Pulled out the magna-guide & hones to touch it up.
I have been at it for about 4 hours over a few days and can't raise a burr!
Marked it with sharpie and it's taking it off perfectly. One thing I noticed is that one grind is wider than the other (shiny bevel edge part). I figured that the guide must not be dead center and reversed it this morning and spent about hour & half on it but still have wider grind on one side than the other.
I then figured maybe the spine isn't cut perfectly level and is producing the different width bevels??
Can't do anything about that right?
I'm using the x-coarse hone (it's prime and broken in) but this steel seems insanely hard.
Do you recommend a higher setting (larger inclusive angle) or maybe a lower one (less inclusive angle) or just keep working it? I have it set in the 3rd notch which should be around 40'ish degrees overall, for the size of the blade (measured spine to edge) according to their instructions.
Comments on any and all aspects of this nightmare project are welcome!!
