DMT stone advice needed.
I need to pick up a diamond benchstone . I've been looking at the different DMT benchstones, and see that there are two different type made by DMT, the polka dot and the continuous surface ones. Example: Polka Dot Continuous
For some reason, the continuous surface ones run $10 cheaper at most places. I want to pick up 2 or 3 in various grits, so that many adds up.
Any quality differences between the two?
If you're in the habit of applying strong honing pressure, the 'polka-dot' surface hones will tend to put fairly deep groove-marks on the blade. Simple solution is to reduce honing pressure, allowing the hone surface to dominate in the honing job.
I think DMT claims the polka-dot depressions allow accumulation of honed particles, thus reducing surface cleaning frequency. My guess is that it's probably easier to produce a good plating job with the holed honing surface.
It 'seems' - no empirical evidence at all - that the continuous surface DMT hones loos honing particles faster than the holed-surface hones.
Personally, I wore out my last DMT hone and replaced diamond hones with sandpaper grits. More grit-flexibility, much larger honing surface and less expensive.
Hope this helps!
I prefer DiaSharp, also only DiaSharp has Extra Extra Coarse available, which I consider as a Jewel of DMT as well as modern sharpening stones.
Thanks, Vassili.
I've got a Duo Sharp in Course/Fine, and just ordered a Dia Sharp in EX Fine. So far, I've been really pleased with the Duo Sharp. It puts a great edge on my knives and doesn't get overly dirty. The only reason I ordered a dia Sharp is because I only need an Ex Fine now, and the Dia Sharp are cheaper in a single grit.
