Try it with a blade first, to see how it removes steel from the edge. Sometimes, when actually grinding, they're a lot coarser and more aggressive than they 'feel' by the fingers. Even if you return it for refund, DMT still won't refuse it if it's already been tried out a bit.
Is it a Dia-Sharp (continuous surface) stone? If so, might compare both sides (assuming it's a single-sided version), to see how it's texture compares to the 'back side', which should definitely be smoother and shinier.
David
