I have two double-sided 6" Dia-Sharp hones (continuous, XC/C and F/EF), and two 'credit card' sharpeners (continuous, F and EF) from DMT. Haven't had any major issues with loading on any of them. They're very easy to keep clean. While using them, if you think they're getting a bit dirty, just wipe them with a damp paper towel or sponge. After each use, just use a little dish soap & water to clean 'em up. It's safe to assume they CAN load faster, because they work much faster than the interrupted surface hones. The entire surface of the continuous hone is covered with diamond, as opposed to the interrupted surface hones, which (obviously) don't have any diamond where the holes are. With all the extra diamond on the continuous hones, you get a lot more bang for your buck on your edges. I'm not knocking the interrupted surface hones. I have 3 Dia-Folds and an 8" Duo-Sharp C/F bench hone, and I like them too. All of them, continuous or interrupted, are easy to keep clean.
