DMT Whetstone
I plan on purchasing one of these for Christmas, Which one do you think i should get? Fine or extra fine? Plastic or wood mounted?
Go with a fine stone in a wood holder as large as you can afford, 8" no smaller than 6", the longer the stone, the easier it is to maintain your blade to stone angle, through out your stroke.
An xtra fine will drive you crazy by not removing enough metal to see what you've already sharpened, great to polish a blade, but the results take forever.
DMT... you must buy the black, blue, red and green ones... then, proceed to Spyderco Ceramic in fine and ultrafine... they will last you forever and you can sharpen anything with a set like that...
In fact only one whetstone (no matter DMT or any other brand) is rather very, very minimal solution and probably wouldn’t fit all your sharpening needs. However if you can afford only one piece right now go with 6-inched DMT fine (red) whetstone. I would prefer plastic based one because it is cheaper with no compromise for performance. Additionally it is more stable when working. I have one wooden based 6-incher and two plastic based ones. In fact wooden based piece slightly (for about 2-3 mm) moves within wooden case what irritates me. This causes me to take the piece out of the wooden base and to put onto one of the plastic ones, this avoids any unwanted movement and allows to sharpen without obstructions.
If you would later consider one stone too few for your needs you could successfully extend your set for necessary grits, coarse (blue) one I could advise as first extension.
IMO 6-inchers would be enough if you do not have particularly long blades to sharpen, say longer than 6 inches. Of course 8-inche long surface would add you good deal of comfort and accuracy when working but they are significantly more expensive. In fact I do not use the whole length of 8-inched DMT sharpening surface when working on 4-inche long blades.
Well, another quite sensible solution would cost you somewhat more money at the first buy but greatly probably it would be more cost efficient in long run. If you can afford somewhat more go with 8-inched double-sided sharpening surface Duo-Sharp in coarse (blue) and fine (red) grits. Get also optional plastic base what significantly rises working comfort and as result – accuracy. This sharpener supported with the set of SPYDERCO ceramic ProFiles (medium and fine) greatly probably could match all your sharpening needs with no exceptions.
Of course no one set could replace you free-hand sharpening skills :)
ok so fine it is? i just realy wna to try my hand at free hand,that sound funny:rolleyes: anyway i have a lansky jig for doing the corse stuff, it just takes off too much metal for everyday use,:( ill check out the plastic base ones if there better...
