DMT XX-Coarse Scratches
When I use this whetstone I get really rough/deep scratches on the edge once finished. I also have the coarse, fine, and extra fine whetstones. My question is after I use the XX-coarse stone how much sharpening do I need to do on the other stones to smooth it out and how many strokes should I be doing for each side of the edge? I don't care about a polished edge I just want it to feel semi-smooth at least. Btw I use steels between AUS-8 and S30V for the most part.
Bit of a loaded question,from black move to blue ,this will leave less scratches.I then go thro the grits to eef.scratches will still be there but less visible.
You can go directly from the XXC to the C in my experience. I only take enough time to raise a burr on both sides with the C after switching to it. This seems to convert the scratch pattern just fine. If it doesn't, you can certainly spent a bit more time with it until it all looks like the C scratch pattern. I then switch to the EF and do the same thing.
Brian.
