- May 10, 1999
Guys, I need your opinion here. I have just received a custom knife I wanted very badly. I draw its design (based on the knifemakers designs - not much of a change here) and we agreed the knife would be finished in mid October (so I could pick it up when in US). The knife was done, but upon closer inspection I discovered the blade was different than the one I wanted. No big deal, said the knifemaker, I will do it once again with the exact blade. Fine with me I agreed.
Now, what is the problem? I got the knife yesterday, looked closely at it (BTW the blade is exactly the way I wanted it) and IMO the liner lock is not the way it supposed to be. It touches the blade only in one point - with very small area. I took some pictures:
Here you can see the lock from the bottom of the knife. The blade is fully open.
Here is almost the same picture, just from different angle:
What concerns me most is the gap between the liner and the blade - do you see the bright triangle? I do realize the liner will wear with use but isn´t the top portion (corner) of the liner too far from the blade? Shouldn´t it be a bit closer? The maker says it is OK, I have no reason not to trust him. But I have many linerlcoks and none of them is like that. So I need your imput here. Do you have knife (with liner lock) that looks like this one? If yes, are you happy with it? I will appreciate any input.
David
PS: This is not to bash the knifemaker in question, I just need more info regarding this type of liner lock. If I hear many people have knives with LL like this I will be perfectly happy with my knife. BTW the rest of the knife is excellent and I am looking forward to using it.
David
