Just ordered my first hinderer should be here tomorrow. do i need to buy the special hinderer tool to adjust the pivot? I see one side can take a flat head. But for the other side do i have to have that special tool? Thanks for any help.
It depends. Depending on the particular knife, and how tight the pivot is, you may very well be able to immobilize the back of the pivot enough just by clamping a thumb on it while turning the front with a slotted screwdriver.
Alternatively, what I did after getting my first Hinderer and before getting the Armorer's Tool some time later, was to take a slotted screwdriver bit of the appropriate size, and a Dremel tool, and grind out a notch in the middle of the front edge of the screwdriver blade to leave two points of the appropriate size and placement to fit the back of the Hinderer pivot. Worked out pretty well, and has the advantage that the bit still fits in a compact bit carrying case.
Third choice is, there's a company called "PSD Products" which has produced specialized bits to fit the pivots of both Hinderer and Strider knives. Don't know if they currently have anything available, but it's worth a google.
Fourth choice, a fastener with holes for two pins, one on either side, similar to the Hinderer pivot, is called a "spanner" - you may well be able to find a spanner bit that fits, thought it feels a bit like if there was a particular spanner bit that fits, it'd be a FAQ in these parts, and I don't recall hearing of it.
And, of course, there's the actual Hinderer tool, which is quite handy. To tell the truth though, what I use it for mostly (because, usually, just finger pressure works on the back), is the screwdriver blade on the end of the tool that exactly fits the slot on the screw for the front side of the pivot, with no play/slippage whatsoever - all three of my Hinderers have been equipped with the add-on hard-to-buy anodized Ti hardware, and you wouldn't want to scratch up those screws when adjusting the pivot. If you're dealing with the plain steel hardware, that's not a concern.
(And order of listing above does not imply order of preference - just the order they came to mind.)
Hope this helps!
Ya i think m just guna grab the hinderer tool. Can you tell me if the lockface of the gen 4 is carbodized?
There are only 3 generations of the 3" XM-18. You might want to check out the info stickey on the front page of our forum.
