- Jul 2, 1999
Hello all,
I have been wanting to get a design etched or coated onto my new Hayes TAC-1 and decided I would try it myself. Here is a before pic:
The design is of a tattoo that I have. Here is the finished product:
And here is a close up:
Here is how you do it:
First clean the blade. Next, cut a piece of duct tape large enough to fit your design on. Place the tape on a piece of plexi glass or similar object. Draw on your design and then, with an exacto knife, cut it out of the main piece of tape. You should now be left with the main piece of tape with the design cut out. Peel the tape off of the glass and place it on the blade. Carefully make sure that the tape is securely in place, if it is not stuck perfectly on the blade the etching material can seep through and ruin the design. Once it is firmly in place pour on some Level 3 Naval Jelly (You can get Naval Jelly in any hardware store, it is a rust remover with an acid base) With a paper towel, blot the Jelly on the design and make sure the Jelly is all over the design. It should have a good thick blob of a uniform coating. Make sure that you dont get ANY Jelly on any part of the blade other than the design. Let sit for 20 minutes. Then, take a clean paper towel and carefully wipe off the Jelly. Now rinse blade under running water until remaining Jelly is washed off. Make sure you get it all off. Now remove the tape, rinse the blade again and wash the blade with some dishwashing liquid, clean and DRY well. There you have it! Instant blade etch. Once completed you should coat the blade in something like tuf cloth to protect the etched area. (NOTE:Remember, the only part of the blade that is "etched" is the design itself. The rest of the blade was covered with the tape.) I am not sure if this etch works on all finishes, so test it first. Good luck and be CAREFUL.
