I used to, after a while I decided I had more consistent results finding a surface that made the finish I was after. As an example, I used to grind a new edge on the 1k and then backhone on the 6k, but not enough to complete the grit. After a few times touching up, I found myself wanting to go back to the 1k before hitting the 6k again, not because the edge wasn't still clean, but because I wanted more tooth. Finally just started finishing on a 4k and leave it at that, going back to the 800 or 1k only when the edge needed repair and not to customize the finish.
Sort of a variation on how I used to finish with a hard Arkansas and then rough up the edge with a few passes on a medium or coarse diamond. Realized I could get a comparable result with better control by just stopping on the "roughing" stone and with a lot less effort and time.
