Do you back-bevel your fixed blades?
I'm wondering if it's normal to back-bevel your fixed blade outdoors knife? Like a KaBar or a Strider.
The edges are still 20 degrees on each side, but should I put a 15 degree back-bevel on KaBars and Strider fixed blades?
Thanks.
The more steel you remove, the greater the chance that heavy work will damage the edge.
I imagine that two bevels would make field sharpening annoying.
I prefer to put/keep a convex edge on large fixed blades. IMO, the best combination of cutting ability and strength.
David
I put a mirror polished back bevel on most of my knives. It can greatly improve cutting ability, particularly if you've got a knife that's relatively thick behind the edge to begin with.
No, my fixed blade are for more harder use than my folders so I just put a 40 degree edge on my fixed and keep it toothy. ;)
Thanks for the responses.
I ask because once I put a back-bevel on these blades, there's no going back.
Especially on my high end semi-customs that I use for outdoors work. :eek:
I've never had a fixed blade shaving sharp, so I was wondering what I was doing wrong.
All my fixed blades came with a 45 degree inclusive angle that I reprofile down to 20 degrees on each side.
Eventhough it's only been 3 replies, I'm guessing it's normal to have no back-bevel on fixed blades..
Thanks.
G'day,
There ain't no normal or usual practice that is worth following. I find it is always best to profile the edge of the blade to match what I want the knife to do.
Fine edges for fine work, thick edges for heavy work, and a convex edge for durability.
Greg
The back bevel is not the edge, and doesn't necessarily affect the durability of the edge at all. Look at where the edge bevel meets the primary grind. You can probably feel the "hump" with your fingernail. Sharpening at a lower angle, but not all the way to the very edge is going to smooth out the hump. The edge stays the same. You can also reprofile to a lower angle all the way, and then put a "microbevel" at a higher angle right at the edge. The first way increases cutting ability by reducing drag (the edge cuts, everything else just adds resistance), and the second way does, too, but with the added benefit of a thinner edge (cuts better, less durable), and a narrower final bevel for easier sharpening.
One or the other is always going to make an improvement in how your knife performs, though the wider edge bevel may not look that great.
You can always try it on a cheap knife or beater and see what kind of difference it makes before doing it to other knives. Your knife will definitely cut better, and you may see an increase in edgeholding.
It's worth trying.
If you're not getting a shaving sharp edge, that has nothing to do with the angle. It's because the two bevels aren't meeting at a point<<<that's all sharpness is. You might try marking your edge with a marker and sharpening, to see where your bevels aren't going all the way to the edge.
I use the back bevel on fixed blades as I find it helps when I've only got a very fine grit wet & dry for convex edges
I do this with kitchen knives as well as outdoor knives
