Klesk
- Jan 5, 2003
When I buy a new linerlock, I check all the normal things: smoothness of opening/closing, full engagement of the liner in both the open and closed position, centering of the blade in the handle. I then perform one more check: with my left hand (I'm right-handed), I fully open the liner (push it up against the scale) to relieve pressure on the blade. Then, with my right hand, I grasp the tip of the blade to see if there is any side-to-side play. This movement may not be evident if the liner is engaged or is bearing on the blade.
If there is any movement, I don't buy the knife. I have found that looseness in the pivot tension can cover up a multitude of sins. For instance, if a loose pivot is tightened up to the point that the blade doesn't move side-to-side, the liner may not engage properly or the blade may no longer be centered (I speak from experience here). I'm also afraid that, if a knife with a loose pivot is torqued while using it, the blade may twist enough to unlock the liner.
This is the number one reason that I stopped buying Benchmade a few years ago; I've never had this problem with Spyderco.
Am I being too picky? Do any of you perform this type of check?
