Everyone I have is pretty much the same, once you crank the pivot screw all the way, it has a preset tension. Loosening the screws creates blade play and wobble.
I like em a little tighter. I use the full arch with my thumb to open all my Spydercos. Not really into flicking.
I see. So you keep pressure on the hole with your thumb all the way through. and control it, rather than flick it open?
Well, the few I have seem to be set from the factory with the screws tightened all the way down. I did try and adjust the pivot on them and it could not be tightened any more than what it was. It wasn't the loctite either. As soon as I loosened the pivot, the blade would become off centered and it would get blade play.When I got my PM2, I was unable to flick it open with my thumb unless I helped it along with some wrist action. I loosened it a bit so it would flick open a little easier. I'm not sure what you mean about the preset tension. If I tighten the pivot screw all the way, it would be unflickable.
