- Mar 7, 2000
or with water?...Any problem with dry only?
True for water stones.Originally posted by Nic Ramirez
Technically youre supposed to let stones soak overnight before using.
http://www.eze-lap.com/about.htm
EZE-LAP Diamond Products has been the pioneer and originator of diamond sharpeners since the early 1970's. Our patented diamond process and modern technology allows EZE-LAP to produce the finest quality diamond products for the lowest possible price. The patented process of heat treatment that bonds the highest quality industrial grade diamond particles in a stainless alloy to a precision matched metal substrate, has been imitated, but has never come close to being duplicated. The resulting surface integrity from the EZE-LAP process measures about 72 on the Rockwell C hardness scale. By utilizing our technology, EZE-LAP has created a surface that works on carbide, ceramic, tool steel, hardened materials and newer stainless steels that are utilized by most major knife manufacturers today.
Ok, thanks a lot, pal, for helping me understand the benefits of your product line. No capitalization or punctuation. Glad he didn't spend too much time on his response. That made me wonder. Hence my question.from EZ-Lap customer service
we use both
http://www.dmtsharp.com/products/
UNIQUE CONSTRUCTION
A perforated steel plate is injection-molded onto a highly engineered, glass reinforced polycarbonate resin base. Precision size micron diamonds are embedded in an electro-plated nickel matrix onto the perforated steel plate. The unique pattern of recessed plastic islands in a sea of elevated diamonds speeds sharpening by clearing away swarf.
Compared to standard sharpeners, DMT® Diamond Whetstones are:
Flat - will never hollow or groove. Easy to maintain constant angle during sharpening. Maintains original tool geometry.
Easy - light, controlled strokes quickly produce razor sharp edges. Sharpens, hones and laps much faster than conventional sharpening stones.
Durable - monocrystalline diamond, the single super-abrasive known for long-life, and tough component materials lasts longer than other diamonds and abrasives!
Clean - use only water for lubrication - no messy oils. Non-porous surface resists loading.
Safe - manual sharpening is temper safe steel and avoids heat build up, which can harm work piece.
Versatile - abrades any hard material: steel, tungsten carbide, titanium, ceramic, glass, etc.
Fast - unique tool pattern speeds sharpening.
Break-in period: Initially your diamond stone will seem especially rough. It will smooth over time with gentle stroking. You need not exert extra pressure - let the diamonds do the work!
Use only light pressure when sharpening. As a rule, 5-10 minutes on a conventional oilstone is equal to about 20 seconds on a DMT® Diamond Whetstone.
Use only water as a lubricant. A lubricant is only necessary to speed the process of clearing swarf into the recessed dots.
After use, rinse and dry whetstone. Store dry. When further cleaning is needed, use an abrasive cleaner (non-petroleum base) and a scrub brush.
http://www.metallographic.com/pc.htm
Polycrystalline diamond as compared to synthetic and natural monocrystalline diamond provides better surface finishes and higher removal rates for metallographic specimen preparation. The features and advantages of polycrystalline diamond include the following:
Higher cutting rates
Very uniform surface finish
More uniform particle size distribution
Higher removal rates (self sharpening abrasives)
Harder/tougher particles
Blocky shaped
Hexagonal microcrystallites (equally hard in all directions)
Extremely rough surface (more cutting points)
Surface area 300% greater than monocrystalline diamond
No abrasion-resistant directionality (abrasion independent of particle orientation)
http://www.alliedhightech.com/polishing/diapolishing/
Allied's diamond compounds and suspensions are available with either polycrystalline or monocrystalline diamond.
POLYCRYSTALLINE DIAMOND has many more cutting surfaces per particle, resulting in higher removal rates. As it cuts, it breaks down in its original shape, allowing for finer finishes in less time than when using monocrystalline diamond. Because polycrystalline has no cleavage planes, it cannot crack or splinter like monocrystalline diamond. It causes less sub-deformation, and is excellent when polishing samples composed of different materials/hardness.
MONOCRYSTALLINE DIAMOND provides a cost effective means for good stock removal and finish. It has a slightly irregular shape with multiple cutting edges, and is recommended for general applications where polycrystalline's features are not required.
http://www.psidragon.com/datasheets/diamond_suspensions.htm
The monocrystalline diamond is a product of high pressure, high temperature technology. The diamond particles are single crystal structures, very blocky and strong. This excellent shape and high particle strength results in an extremely closely graded powder. These color coded suspensions are recommended for polishing on metallic and many non-metallic materials.
The polycrystalline diamond is a shock synthesized product, producing a strong, multi-edged particle. The resulting particles are very strong, such that cleavage fractures will not occur. The polycrystalline diamond particles are black in color, resulting in shades of gray coloring of the suspension. This product is less frequently used, and is recommended for polishing non-metallic oxides and electronic components.
Yeah, EZE-Laps are heavy. A flat steel slab, kinda thick. The DMT's have a stiff polycarb resin substrate, with a thin steel plate on top w/ diamonds attached to the plate w/ electroplated nickel. They are flat, stiff, light. Maybe a bigger issue for those toting to the field.Originally posted by Brommeland
E-Z Laps...sucked... They were heavy to carry around...
Same here. The Lansky clamp is decent, aluminum doesn't scratch blades, but it's not perfect. The DMT clamp kinda sucks... plastic-y.Originally posted by Brommeland
I use a DMT, with a Lansky clamp. This combination is the best of all worlds.
What is a Fold-A-Vee? Sounds like a V-crock stick, ceramic?Originally posted by Brommeland
I then finish on a Lansky Fold-A-Vee...
Please elaborate, at least briefly.Originally posted by Cliff Stamp
Regarding wear, the DMT's are guaranteed not to wear out, the Ez-Laps are not. I have used both, the difference is obvious.
-Cliff
Cutting fluid... have always wondered what this accomplishes. Not that I doubt it. What are your (anyone) collective experiences here?Originally posted by Rick Leeson
I use WD-40 on my DMT stones. It makes a great cutting fluid.
