Just got it. Great design - I'm quite happy with it. I'm not sure if any data was posted regarding lock strength tests, but fro some reason, it was my impression that this model was part of the MBC series, however, it seems otherwise; it's not as stout as the other folders in the MBC line. There are no inlayed liners in the G10 scales, the pivot is not of the large variety and I have no idea if the lock is durable enough for an MBC rating.
Regardless, it rides very discreetly, is very legal, light, slim, fits well in the hand, and is pleasing to the eye.
The blade seems to have great cutting efficiency for 2 inches. Add the Spyder edge and I don't know if it could get much better. Also the grind, particularly along the downward slope from the spine to the tip is very well done.
When closed, the blade isn't held in place as strongly as the ball bearing detent on my Salsa. This is due to the spring loaded piston on the ball lock. It seems that if the spring was stronger and provided more resistance against the ball, the blade would not open so easily from the closed position; also this increased pressure would eliminate the side to side play when closed. It seems there is a reason for everything that Spyderco does and I wonder why a stronger spring was not considered for the piston.
I like the how the back spacer replaces a stop pin and how the angled front portion of the spacer is flush with the "tang" of the blade. Also, the dual finish of the blasted -type on the spine and the satin finish on the flats is a nice touch.
Because the tang rides along the ball when opening the blade, I thought the action would be smoother. For lack of a better description, the opening is a bit "scratchy."
I don't want to come off as too critical...I love this knife. Just want to throw in some input. The Dodo is unprecedented in design and function and is a must have for Spyderco enthusiasts. My regards to Eric Glesser and the Spyderco crew.
