Originally posted by Lavan
I swear, I can work up a sweat putting a good edge on ANY knife and without USING it, it will be dulling in about a week and a half.
Maybe it is the touching it to see how sharp it is every day.
I believe a person's skin oils can be on the acidic side
Originally posted by Sgt 127
I think the same thing happens to me. This is a pretty low tech answer, but, if I REALLY work at getting a knife really sharp...when I go back to it, it doesn't seem as sharp. I don't know if my fingers get numb, or, I just decide its as sharp as its going to get and stop, only to play with it later and realize it wasn't as sharp as I thought it was...Seems pretty simplistic, but, I'm sure its happened to me.
Wow, I never thought of it this way. So too much pressure causes the metal to deform the way you want, but doesn't really remove metal as efficiently?Originally posted by Cliff Stamp
If you steel or strop the edge as a finish this is the expected behavior as the edge will relax back to its predeformed state quite quickly. You can see similar effects to lesser extents on v-rod sharpening depending on how much pressure you use.
