I was wondering if anyone tried to grind a little detent ramp on the blade tang with a dremel.
If you have, please let me know how it went. Was the result satisfactory?
Im unsure if I should try it on one of my knives.
Thanks
^^^This.Don't dremel your freaking blade tang.
Because metal is easy to remove, but not put back on. It's easy to take of to much and be beyond the point of no return.Im confused... why do you not recommend using a dremel??
At least not without welding some new steel on and then filing, grinding and in general reconstructing your tang. But wouldn't matter too much since the welding would almost certainly destroy the manufacturers heat treating. lolBecause metal is easy to remove, but not put back on. It's easy to take of to much and be beyond the point of no return.
We weld up certain accidents at our machine shop, you can get away with it in some instances. A liner lock doesn't seem like a good instance for weld repair, maybe tig very carefully but still... not a good situation.At least not without welding some new steel on and then filing, grinding and in general reconstructing your tang. But wouldn't matter too much since the welding would almost certainly destroy the manufacturers heat treating. lol
Always making mountains out of molehills here. File or dremel makes little difference. It's the skill of the user.
So.... why people freak out about using Dremel??? Cant you change the rotation setting to the lowest and grind very slowly & carefully. like a file?? QUOTE]
It is just too easy to make a mistake with the Dremel. Many factors are working against you.
Many people are inexperienced and don't understand what it takes and what can go wrong.
They may forget to mask off areas that should not get touched to protect them.
The dremel is essentially a gyroscope in your hand and it will fight you at times depending on the speed you are running. Faster it is more stable, but also with speed comes the ability to get into trouble faster. Your bit grabs a bit and the force sends it off into pristine material.
Probably the biggest factor is because it is a powertool, people think they can rush it. Hand tools helps force you to take your time. At least in theory. lol
It's mostly because no one knows anyone's skill level and recommending the use of a dremel tool in general knife discussion might not be the best advise. If you are confident in your skills, then go for it!So.... why people freak out about using Dremel??? Cant you change the rotation setting to the lowest and grind very slowly & carefully. like a file??
I do not understand.
Yes... but why so many people freak out tho?
Not starting anything here. Just saying that to you they are just tools. To others they may be investments, and others pieces of art. Certainly not condoning anyone freaking out, just trying to understand or appreciate it from their point of view. We are all in the game for our own reasons.Everyone is an expert. Knives are just knives. Not jewelry unless someone wants it for jewelry. Just a tool. Got a box or two of tools, horror of horror, dey gotz grease on 'em! Nothing made by man or maintained by man is perfect. Freaks just freak out, Mon!
