MAM is a Portuguese maker of knives. I believe MAM are the initials of the founder.Is MAM an acronym?
I wanted one with the silhouette of a greyhound chasing a rabbit (as I have greyhounds) but they seller wouldn't ship overseas. When I go to Spain and Portugal next year I WILL have one, I promise!!I recently became aware of these knives. They seem light and compact, would be a pleasure to carry. Blade geometry seems to be great for most daily jobs. Have they served you well? Have you ever been let down by it?
I do have two non-locking models I carry every so often. A "large" sheepsfoot and a "medium" "clip point". (The "clip point" looks more like a spear point to my six (with bifocals) old eyes. What do y'all think?) Both are the same length closed; about 1/32 inch shy of 4 inches..Doesn'tafishhunter carry one?
What is this "Swell lock?" If the pivot is loose, you can peen the pin to tighten things up again.I do have two non-locking models I carry every so often. A "large" sheepsfoot and a "medium" "clip point". (The "clip point" looks more like a spear point to my six (with bifocals) old eyes. What do y'all think?) Both are the same length closed; about 1/32 inch shy of 4 inches..
FWIW IMHO they cut and slice better than my Opinels.
D dogstar They've never let me down.
I did have to add a little nonadhesive 'SWELL LOCK' to the pivot end tho. They keep the AC on here a bit more than necessary, in my humble opinion. All four of my friction folders needed the treatment. The blades were dropping half open or closed by gravity.They all behave after applying the Swell Lock.
If you want my opinion, it's: "Get the one(s) you like. They're great."
I bought the nonlocking versions because (a) I never use the lock on my Opinel, and figured "Why get a feature I don't need or want?" and (b) "The liner lock version costs a couple bucks more. Why pay extra for a feature I don't want or need?"
Unlike the Opinel blade lock, which can be used or not, the MAM "Press To Release" liner lock engages whenever the blade is opened.
A wood swelling compound, usually used in furniture restoration for tennons that have dried out and shrunk over the decades or centuries.What is this "Swell lock?" If the pivot is loose, you can peen the pin to tighten things up again.
I am considering the locking drop point and the 2-1/4" non-locking sheepsfoot![]()
I think if you found a way that works, stick with itA wood swelling compound, usually used in furniture restoration for tennons that have dried out and shrunk over the decades or centuries.
One could peen the pin ... if you can also compress the "bolster" I suppose. However, I would be/am a bit hesitant to do that (plus I lack the proper tools and a suitable vise at this time), since the problem is caused by very low humidity. If/when I carry them in the "humid" Southern Idaho summer, they will swell a bit. If the bolster has been squeezed even tighter (it isn't lose) to make it possible to peen the pin to tighten it up, I'm afraid the handle may be damaged.
If I was a bit wealthier, the fix would be easy enough ... commissionglennbad or another modder (who's books are not closed), to make new handles from stag or horn, or possibly Micarta or some other synthetic.
Since I ain't, the Swell Lock makes them usable.
