Straightfromtheinkwell
Basic Member
- Aug 6, 2023
I'm aware you can use anything for the pivot but the rest of the hardware you really do need the specialized bits
maybe but shiro uses male screws sometimes and idk how I'd make my own bit for one of thoseYou want cheap… how’s this? Make your own. I made my own out of a nickel. Just file it until it is thin enough on one edge, then a couple corners to make it the width of a narrow screwdriver bit. I liked it because the nickel was softer than the screw head so it didn’t scratch it. I’ve made pivot tools for other knives out of nickels as well, such as a Hinderer that is a wide screwdriver with a slot in the middle removed.
You just use little diamond files or what? I may try that.You want cheap… how’s this? Make your own. I made my own out of a nickel. Just file it until it is thin enough on one edge, then a couple corners to make it the width of a narrow screwdriver bit. I liked it because the nickel was softer than the screw head so it didn’t scratch it. I’ve made pivot tools for other knives out of nickels as well, such as a Hinderer that is a wide screwdriver with a slot in the middle removed.
REK bits work on Shiro hardware? Do you have a pic or link to illustrate? I'll have to seat around for that..I have the bits from REK knives that work great
I have a couple small (6”), thin hobby files.You just use little diamond files or what? I may try that.
Not sure what cheap means for a > $500 knife. Check out Josh's website: https://rek-products.myshopify.com/products/shirogorov-tool-bits
PS: posted parallel to Jacob ....
Availability is one factor.I’m still trying to wrap my head around why someone would want cheap bits to work on an expensive knife.![]()
Availability does not coincide with “cheap.”Availability is one factor.
Shirogorov, Microtech, CKF, and more have sold tools for their hardware but they tend to sell out quickly.
Does the cost really matter if the tool works?Availability does not coincide with “cheap.”
That’s my point too.Does the cost really matter if the tool works?
Put “bit” into their search bar the results are mind blowing.Did you guys ever look through McMaster Carr?? Maybe you can find something close and modify it.
I found spanner bits there for the Hinderers (see below link):
McMaster-Carr
McMaster-Carr is the complete source for your plant with over 595,000 products. 98% of products ordered ship from stock and deliver same or next day.www.mcmaster.com
McMaster-Carr
