"I have found that if one can duplicate the conditions that the industrial specs use, that L6 will respond very well to the recommendations on those same spec sheets. If you can, soak the snot out of it! It will harden quite deeply and be nearly indestructable. "
Are you referring to the Admiral stuff or Crucible's? I've noticed that the Admiral L6 will make a very visible transition zone if edge quenched. That makes me wonder if it's deep hardening.
"Now as for the Admiral stuff, since I have yet to see a chemistry that exactly matches its behavior I am going to take some guesses here, but don't worry I will try to make those guesses as educated as possible, and I have successfully treated the stuff. I would say that you could heat treat it similar to 5160 or 4340 and heat it to around 1525F (my safe estimation) and soak for as long as you can perhaps not exceeding 15 minutes. If that soak is too long for ones facilitites then I would go to 1550F for a shorter time."
Sounds like a good place to start. I have an Evenheat oven so soaking is not a problem.
"Quench into a good medium speed oil. And then begin your tempering at 400F to stabilize things, but you may need to go as high as 440F to get in the range of 58HRC, if your soak time was longer. If you just got it to temp and then immediately quenched, 400F may be enough. There are a whole spectrum of but's, if's and other exceptions due to all the factors that could change things, but that is my ball park recommendation overall."
The only "engineered" quenching oil I have is Shell H201, which is almost identical to Texaco type A. Do you think this is too slow?
"edited to add: BTW you will know if there is moly there if you have to use the higher tempering temps in order to get the desired HRC. I don't think it is there in this stuff, or if it is it is not as much as the typical batch from Crucible."
I have no way right now to check the hardness, other than files and the brass rod test, for what those are worth. A Rockwell tester is at the top of my wish list right now.
Judging from how soft the Admiral L6 is after normalizing, I'd say it doesn't have moly. Just a guess though. It sure acts different than champalloy.
"*edited to change 68HRC to 58HRC as Raymond so rightly pointed out"
I knew what you meant.
Thanks again for the help.
