"Features
CBN grit size is about 40 microns
CBN abrasive is significantly coarser than the medium ceramic stones
CBN rods should be used with VERY LIGHT pressure. Recommended use of less than 5 grams (there are 28 grams in an ounce) and excessive pressure may shear the abrasive off the base layer that binds it to the rod.
Recommended misting the rods with water before use to reduce metal dust and slow the abrasive process
The rods are ideal for reprofiling the bevel angle of a knife or rebeveling chipped or nicked blades
Because the abrasive is coarse, users should expect a bit of work with the medium stones afterward if they want to smooth the bevels to the finer grit"
Can some one tell me if there is any real difference (i.e. In the scratch pattern) between the CBN rods and the Diamond Rods for the sharp maker? Or if there would be any reason to own both.
