It just feels like it is harder than some of my other knives with the same steel. Just curious if anyone knows.
The CPM prefixed steel are "powered" steels using Crucible's Particle Metalurgy. Some of them, like CPM S30V are patented, proprietary to Crucible and only available as particle steel. Others, like D2 and 154CM are older steels and available from a number of makers in regular form and from Crucible as a particle steel. Crucible may also supply regular versions of those steels. CPM 154CM will have different properties from 154CM, like a finer grain structure, even if the chemical composition is the same.Just look for a spyderco knife that is made with this steel and most everyone lists the hardness in the specs.
And I have to add that I wished they would use the CPM 154 cm instead. The martinsite grain structure is much tighter with the carbon properties being much smaller thus tighter and closer together. Now someone told me that the CPM was just a prefix or something for D2, 154 cm, etc etc. Then why do they list in the interactive steel chart CPM D2 and D2 in seperate rows. The same for CPM 154 cm. Now you can see a microscopic blow up of the CPM 154 CM and the 154 cm on Knives ship for free website. CPM 154 being a superior steel than the plain 154 cm. As for the hardness you can only see that on the interactive steel chart. Not even sure they give that but they may give the range of which it can be hardened to practically for a knife.
I did do a brief hunt for its hardness at bladehq but it did not list its hardness for the native I found in 154 cm at bladehq. I must continue now because you have my curiosity up. For me I like their knives that are made from CPMS30V. Could not find a non crucible form for CPMS30V and that may be because there is not one. The reason for that is because it was Chris and Crucible invented the CPMS30V together.
But I will continue to try and find the non crucible 154cm in a spydie knife that lists the RC with it.
http://zknives.com/knives/steels/steelchart.php
cajun
CPM154CM
Paul
My Personal Website ---- Beginners Guide to Spyderco Collecting ---- Kiwimania ---- Spydiewiki
Dead horses beaten, sacred cows tipped, chimeras hunted when time permits.
WTC # 1458 - 1504 - 1508 - Never Forget, Never Forgive!
It's easy to grin when your ship comes in and good fortune and fame are your lot, but the man worthwhile is the man who can smile with his shorts twisted up in a knot. - Morey Amsterdam
Given the fact that Spyderco has worked with CPM S90V and M-4, I'm sure they have the equipment and skill to work with CPM 154. They chose 154CM for the base model version of the Manix 2 because they wanted to position the Manix 2 as an entry level knife and 154CM was a good, but inexpensive, steel. Sal explains the logic here, if you're interested and have not already seen it.But still if someone wants to see the awesome difference using the crucible form of a steel makes that photo on knives-ship-free site. Actually I will go find it and put the link here. It makes a huge difference when it is in the powerded/crucible form. But there is probably two reasons that most companies do not use CPM-154-M. You have to have the right equipment to deal with the stuff and you have to be extreemly skilled to work with the stuff. At least this is what I have read.
As for hardness, Spyderco does publish figures, but Sal might chime in with them or may have done so at some time in the past.
Paul
Crucible D2
For clarity, do you mean Crucible's D2, or Crucible's CPM-D2? They have made both, although based on their website only ingot ("regular," non-CPM process) D2 seems to be available now.
Now you are getting funny. I looked back and all you have done on this thread is answer back to my first post and you keep building on that. You never once attempted to answer the Original Posters Question. I like learning but it seems you are on a big ego, pride, self esteem or attention seeking adventure or something!>>>What ever ---- I tried to boost you a bit in my last post and thought that would give you the attention you seek. But I suppose I was wrong.
So maybe do this. For once give your attention to the original poster for you have not done that at all yet. Now I am finished with this thread since i cannot find the answer for the man "yet". I will pm him if I do.
Now if you feel a need to teach the public I suguest you start your own thread. I do have questions on the topic you seem to want to stay on. But when I want advice I ask for it. And I do not remember asking in this thread. Now as I mentioned you may be the one to start such a thread. You seem to know a little anyway.
cajun
You are correct. I was trying to avoid naming brands but I was referring to some of my benchmades. I have a few buck fixed blades with bos HT in this steel as well, and the Spyderco just seems harder. If I were to rank them, it would be the spydie, then buck, then benchmade. I love my benchmades too, and this is not meant as a bash, it just feels likt the Spyderco is heat treated harder.
