Does anyone know what woods were used to make handles for old Hi-Carbon kitchen knives?
I have some old Hi-Carbon steel kitchens knives that need new handles. I was curious if anyone knew what woods were commonly used to make the original handles for the old Hi-Carbon knives. I would like to replace them with the same species of woods that were common back then to keep up the authentic vintage feel of the old knives.
Thanks,
Nimrod
Apple wood was common on older knives too. Chatillon / Foster Bros made mention of it in some old ads, and some old government contracts specify it too.
hickory was used a lot, as were other nut woods. The important thing to remember is when those nights were made no one put their knives in the dishwasher; there was no such thing as an automatic dishwasher in a home and for the most part, nor were they available in restaurants. So those old knife handles worked heated to near boiling temperature and then sprayed with caustic cleaners, and spray it again with hot water to rinse all the soap and debris off. Some of those old handles lasted just about as long as the knives did!
I re-handled a couple of kitchen knives with hickory that I harvested from a broken sledgehammer handle and it worked great. Although not the prettiest, the most water and where resistant would I have used to rehandle knives or to supplement a knife kit is White oak. That stuff is almost impervious to wear.
I thought I would give White oak a try after reading that it was the wood of choice to build the seafaring ships from the 1300s on up to the turn of the 1900s. If it can take all the wear and tear of a saltwater voyage I thought with just a minimum of care it would be great for a knife handle. Put the first ones on about 15 years ago and none have failed yet!
White oak is pretty impervious to water due to the tyloses in the pores.
It has a coarse grain, so you need sharp edges to get the final smooth surface.
On the downside, it is very high in tannins, so it may corrode the carbon steel of the knife tang. You can use a synthetic liner to prevent that.
It is also has less dimensional stability than walnut ( which has tannins too, by the way).
For a beautiful, water resistant, very sturdy and stable handle material, try cocobolo, or at least Indian rosewood. The latter is sold from several species, use the true Indian rosewood (Dalbergia latifolia). Indian rosewood can stink, but the smell goes away with time. In the timber trade Indian rosewood is frequently used to denote a wood from a similar species, Dalbergia sissoo too. Sissoo wood looks similar, but is usually less dense, and I have seen even punky or low grade wood sold as higher grades. The wide color variation in this wood is often accompanied with wide density variations too. In order to get a better grade, look for a wood which appears more uniform both in color and density. This is in contrast to the features preferred in cabinet wood, where “striking”, varable, “pretty“ wood is preferred. If you can select yourself in a woodworking store, look for the heaviest, densest, most uniform examples without knots or checks you can find.
Cocobolo is nicer but might be more expensive. Both are naturally oily woods, so it would be more challenging to apply a finish on them, but not impossible.
Cocobolo was pretty much standard on better working knife handles in the late 19th, early 20th centuries, which attests to its durability.
Actually made by an old company caled Wasgington Forge. They used Hickory handles.
