Does anyone like old churches?
The weather has changed finally, after the wettest June ever! So took a trip down to Oxfordshire to relax and take a few snaps. I thought I'd share the church ones as there were a few gems down there.
Medieval church architecture is traditionally divided into 4 periods with distinctive styles, namely Norman, Early English Gothic, Decorated and Perpendicular. They correspond very roughly with the 12th century (1101-1200), the 13th century (1201-1300), the 14th century (1301-1400) and the 15th century (1401-1500). It is very common to find all four styles in the same church as the buildings were altered, repaired, extended and modernised over the centuries.
Prior to the Norman period was the Anglo-Saxon or pre-conquest period, around 600-1066. There are practically no complete Anglo-Saxon churches though and surviving remains are rare enough to generate a frisson of excitement even in the seasoned church visitor when discovered.
The Perpendicular style merged into the post-medieval Tudor style which was in turn superseded by the various periods of classical revival, until the gothic found favour again in the 19th century. Church building became much less frequent after the middle ages and before the 19th century so most of the upstanding church fabric across the land is either Medieval or Victorian and it is not so easy to tell the difference at first glance.
On to our first church:
St Kenelm's Church, Minster Lovell. The church was substantially rebuilt in the 15th century by the Lovell family who occupied Minster Lovell hall, a grand building that stood just behind the church.
The typically 15th century/perpendicular font, with it's rectangular panelled decoration.
A perpendicular style window, with some surviving medieval glass.
Another perpendicular window, with ancient glass fragments. The name perpendicular is derived from the way the window mullions pass right through the tracery to meet the window head.
And another.
View through the central crossing tower to the East End.
Some very detailed medieval painted glass in that perpendicular east window.
A fine altar tomb to Francis, 9th baron and 1st Viscount Lovell, and adherent of Richard III, for whom he fought at Bosworth Field, 22 Aug. 1485. http://en.wikipedia.org/wiki/Francis_Lovell,_1st_Viscount_Lovell
This little door presumably provides access to the belfry in the central tower via a passage within the flying buttress.
St Mary's Witney. A rather impressive church but there was an event going on inside so the interior was not open for viewing. The large window in the north transept is late Decorated, The narrow lancet windows in the chancel to the left are Early English in style but could be Victorian. The high windows in the nave clerestorey to the right are Perpendicular.
Some unusual chest tombs in the churchyard.
Abingdon: The gatehouse to the long gone Abingdon Abbey. Beside it is the church of St. Nicholas, which was built in the 12th century, though the windows in the south wall are 15th century and the east window is Victorian.
Door from the gatehouse into the church.
A royal coat of arms in this early 14th century window. I imagine the glass is 18th century or thereabouts.
More old glass in a 15th century window.
Back out into the country again, St Michael's church, Cumnor. The clerestorey windows are late Perpendicular.
In the churchyard, a restored Easter Cross.
Early 14th century window.
Superbly preserved Norman corbels! It's quite unusual to find these, which originally ran just under the eaves of the roof. The wall was extended upwards in the 15th century to form a clerestorey, the windows of which provide extra light to the Nave.
Below the corbels, this rustic, blocked, square-headed doorway. Anglo-Saxon?
The west tower is entirely Norman and almost unaltered.
Inside the Victorian porch is this medieval, or at least very old, door.
A 15th century font in front of the 12th century tower. The arch though, above the capitals, is a later remodelling.
Inside the tower, stretching up to the belfry, is this amazing oak newel staircase. On the newel post are carved initials and the year 1685.
The scalloped Norman capitals below the tower arch.
The late Norman north arcade. There is no south aisle.
A Norman Window
North Leigh church, which has an intact Anglo-Saxon tower! The steep roof line of the original Anglo-Saxon church can be seen against the tower.
These coffin-shaped grave slabs are quite rare elsewhere but there are quite a few in this churchyard.
One of the distinctive Anglo-Saxon belfry openings in the tower.
The arcades are Norman but the thinness of the wall they are cut through suggests that it is Anglo-Saxon.
Above the stone rood screen is a dramatic doom painting.
Next to the chancel is this beautiful perpendicular chantry chapel with a fan-vaulted ceiling. The East window contains a substantial amount of high quality medieval glass.
The medieval glass.
Nice 15th century stone tomb bearing the alabaster effigies of Sir William Wilcotes (d.1410) and his wife Elizabeth (d. 1445).
Hope you like!
As usual, always a treat to take the trip along with you.
Thank you for the beautiful photographs! I shall return to them often.
This is All Saints, my parish church in Chicago.
All Saints was built in 1883, six years before Ravenswood Township was annexed by Chicago. Its American Victorian architecture is called Stick Style. It is a balloon frame wooden church which some misguided rector decided to stucco early in the 20th century. Stucco saves the expense of annual repainting and siding repair, but its weight is just a little more than the structure can bear, and those steel cables are all that keeps the walls from tumbling down.
The stained glass is mostly geometrical. Anything representational would have been too papist for them, but they loosened up a little during the 1920s. The High Altar (which is never used) is a marble Italian import purchased for a song from a Catholic church the Archdiocese closed during the Great Depression.
The poet and historian Carl Sandburg lived two blocks away, and he put All Saints in a poem:
MRS. GABRIELLE GIOVANNITTI comes along Peoria Street
every morning at nine o'clock​
With kindling wood piled on top of her head, her eyes
looking straight ahead to find the way for her old feet.​
Her daughter-in-law, Mrs. Pietro Giovannitti, whose
husband was killed in a tunnel explosion through​
the negligence of a fellow-servant,​
Works ten hours a day, sometimes twelve, picking onions
for Jasper on the Bowmanville road.​
She takes a street car at half-past five in the morning,
Mrs. Pietro Giovannitti does,​
And gets back from Jasper's with cash for her day's
work, between nine and ten o'clock at night.​
Last week she got eight cents a box, Mrs. Pietro
Giovannitti, picking onions for Jasper,​
But this week Jasper dropped the pay to six cents a
box because so many women and girls were answering​
the ads in the Daily News.​
Jasper belongs to an Episcopal church in Ravenswood
and on certain Sundays​
He enjoys chanting the Nicene creed with his daughters
on each side of him joining their voices with his.​
If the preacher repeats old sermons of a Sunday, Jasper's
mind wanders to his 700-acre farm and how he​
can make it produce more efficiently​
And sometimes he speculates on whether he could word
an ad in the Daily News so it would bring more​
women and girls out to his farm and reduce operating​
costs.​
I was told that Carl showed up on holidays when he felt depressed or lonely. As you might guess from the poem, All Saints was too bourgeois to suit him and too Anglo-Saxon. I don't think he would have that problem today.
That tower looks a little Scandinavian to me :)
So the iron tie rods are a later strengthening addition? You often see similar tie rods in Victorian timber buildings as part of the original construction.
Great pics. When the wife and I got married 16 years ago, we held the wedding at a very small country church.
It was built in the early 1900's. There is a small cemetery out back, where the people who helped build the church, are buried...
All the pictures we have, were taken before we had a digital camera, so I don't know how to post them. I just looked to see if they have a website, but they don't. I'll try to find some pictures on the internet to post.
No, those flying curvilinear rafters were put there for decoration, not as mooring posts for iron tie rods. The architect knew his business, and he used just enough wood to hold up the walls, the roof and the steeple. When they stuccoed it a generation later, they put lath over the siding, heavy asphalt roofing felt over the lath, and lime stucco (a kind of cement) over the felt in three layers. That is quite a load. I don't know whether iron tie rods were part of their plan, or something they found was needed later.
Now we are stuck-o with the stucco and the tie rods. All Saints is a designated historic landmark: we would have to document that the wooden siding underneath the stucco was the original exterior, and that our restoration would exactly match what was built in 1883. It ain't happening.
Having read Ursula K. Le Guin at an impressionable age, I thought it looked like a deformed penis. Thank you for "Scandinavian." I will try to remember it: even IKEA and lutfisk are more pleasant associations.
Wonderful pictures!!!! I love seeing all of this history, we just don't really have architecture like this in America, I get excited seeing things from the 19th century but it can't really hold a candle to stuff from 500 years ago. so cool! post more, love to see them
Beautiful pics A.W.U.K., nice contribution from you too Piso, thanks for sharing. As a young Sailor on liberty, these weren't exactly the establishments I had on my radar. However, as I got older and my U.S. Navy career progressed, my interests changed (imagine that) and I began to appreciate the beautiful architecture overseas. Too bad digital cameras weren't available, but I did capture some nice negatives (film shots) of some mighty impressive Church's in Spain & Israel.
I don't have any pics.... It was 1965 or so... While knocking around the Alps in Germany on leave we investigated several old stone churches in the area. The difference between these (mostly Lutheran, I gather) old buildings and the ones pictured above is striking.
Very, very stark. Almost no decoration either in architecture or furnishings. Big, heavy-stone chambers. And, in the middle of Summer, almost cave-like temperatures!
While in Paraguay last summer we took time to visit the church of San Bonaventura at Ygauron which is south 40K outside of Asuncion. The roof style is a two plane typical roof and around the perimeter of the building the roof line extends over a walkway. There would be room to seat a large number inside and with the windows open many more could gather around the outside. The church dates from the late 1600's and is decorated in the rococco style with the ceiling and support timbers painted in bright geometric patterns. Sorry, no pics but the next time I go there I need to get out and look at the Jesuit mission sites scattered around the country between the capital and Brazilian border.
The churches above are also very cool in summer, something that is not so easy to imagine looking at pictures showing the warm light coming through the coloured glass windows.
Wow great stuff. Love old buildings. Saw some old churches in Ecuador few years back. One had catacombs under it. But we were not permitted to go in. Some of the symbols are ears of corn. I think the guide said they used corn over grapes
