the blade warping only appeared after i wiped the knife on my jeans.If edge retention in use is normal or typical for such a knife, it means the heat treat is likely OK. Whether the blade warped or not, during heat treat, doesn't necessarily mean the heat treat was bad. Sometimes blades will warp in heat treat or quench; but the only issue there is whether the maker deems it bad enough (aesthetically) to reject it or let it pass.
A lot of traditional pocketknives with small blades & very thin grinds will show a noticeable warp to them. But the very same knives can still sharpen up and work just fine, even beautifully, in use. I have a lot of them like that.
That's bizarre.the blade warping only appeared after i wiped the knife on my jeans.
If you do return it to Opinel, don't mention the part about wiping it on your jeans.the blade warping only appeared after i wiped the knife on my jeans.
i sharpend out all the warpingWould really like to see a picture of the warping. Nothing makes sense otherwise, without the visuals...
You say the blade was warped, but most of it disappeared when sharpened. If a blade is warped, sharpening is not going to remove it. You say you used it for food prep. Were you cutting on a ceramic plate and turned the edge? If the edge was turned by contact with the ceramic plate, which would dull any edge, then yes, a bit of sharpening may take it out.
If you look down the spine, (back of the blade) is it strait or does it have a curve to one side or the other in the blade slot?
If the edge proves to be stable after the damage was sharpened away, then there's probably little else to worry about, in terms of the heat treat.
