My BM 556 appears to stop the closing blade by the edge contacting the grip interior. I don't see a kick and the axis lock obviously does not wedge against the small choil behind the edge.
On my griptilian, the axis bar engages the choil to stop the blade upon closing. There is more than a couple of mm of space between the edge and the interior of the knife
You can test if the blade is indeed stopped by the axis bar.
With the knife closed pull the axis bar back like you were going to axis flick it, but don't flick it. While still holding the axis bar back, squeeze the blade like you were trying to close it even more than it already is. While still squeezeing the blade closed, release the axis bar. If it goes forward then the blade isn't being stopped by the axis bar. If it stays back for as long as you squeeze it, then the axis bar is stopping the blade.
P.S. Mine stays back, and the blade is therefor stopped by the axis bar.
This is not normal, nor acceptable. If you send it into Benchmade, they will repair/replace it free of charge and have it back to you in just a little bit.
I think it's an indicator of a 'better quality' folder that the blade never contacts the spine of the knife, even when snapped shut.
This goes for 'modern' designs, I understand that slippies and other classic folders behave differently and must be closed with care.
However, I love being able to snap my Griptilian open and closed, with no worry of damaging the blade. Probably not the best thing in the world to do to a folder, but it's an EDC user, so there you go.
