Does the guy with the most motors, win?
I was looking for some space, to put a new machine, in my smithy and found, to my dismay, that there was none. Isn't it amazing how quick the space, disappears.
As I looked about, I started counting the number of motors that it takes to run my shop.
I am not speaking of hand tools. I am talking about standing machinery where you can get your hands around the motor. Buffer, drill press, grinders and the like. I have 13 motors :eek: in a 20x16 foot shop. I know this is not excessive by knife makers standards. So tell us; how many motors do you have running your shop?
I have heard it said; "The guy that ends up with the most toys, wins" I have never bought into that, but the guy with the most motors means the guy with the most machines. Now that might make sense to me.:D
Happy holidays, Fred
Hmm lets see.
1)Wilton variable speed 2X72
2)1Hp Buffer
3) Delta Drill press
4) Metal cutting bandsaw
5) 4 inch belt/disc sander
5 machines for workin
I don't know if the dust collection machine or the paragon HT oven count so I leave them separate.
Shop size 8 X 10
Never thought of it. let see KMG 3hp, drill press 1hp, buffer 1hp, metal band saw? , wood band saw? press, and a 3hp mill. Guess I cant count the 4 spares they just eat up space
in my 12x16 shop. Dang I don't win
Dang, never thought about it that way, Fred.
I count 17 motors on stationary tools. Plus two Foredoms, so 19 altogether.
And, of course, there's another grinder I would just REALLY like to have next year, if I can find space. LOL
Edited to add: add 4 for the MIG, chopsaw, compressor for the sandblaster and grinder out in the garage.
I sure hope my wife doesn't see this thread.:eek:
It is both awe inspiring and a little scary when you finish counting.:D
I had the same thought about my wife.
Fred
I keep remembering more, too! The blower on the forge, the Darex drill sharpener, the small buffer on the engraving bench, the scroll saw....
It's sort of humbling when you stop to think about some of the art that comes out of third world countries where a craftsman sits on the dirt floor and turns out these works of beauty with absolutely ZERO power, using his bare feet for a vise.
No truer words were ever spoken.:o Fred
Watch out ! When all your motors are running -if your wife turns on the Christmas lights - POP goes the breaker !
Hmmmmmmmm.....
  1. Drill press
  2. Table saw
  3. Compound mitre saw
  4. Abrasive cutoff saw
  5. Wood cutting bandsaw
  6. Metal cutting band saw
  7. KMG
  8. Air compressor
  9. 2x42 belt sander
  10. 1/30 belt sander
  11. 6" stone wheel grinder/buffer
  12. Shop Vac/Dust collector system
  13. Router table (probably doesn't count, since the router can be taken off and used as a hand tool)
and I'm looking at getting the 'Chevrolet Smoker' that is pictured in the attachments. If I get this, I'll win hands down! The guy that designed and built this thing had to be a knifemaker!!
mete...I think that we might be able to actually sing your post to the tune of "Pop goes the weasel". If you don't believe me, try it.
Yes, I'm strange!
Well let me see here;
#1 Bader 2x72
#2 Berryman 2x72
#3 Another Berryman 2x72
#4 Delta Rockwell 6x48
#5 Unknown Brand 3x86 Wet/Dry with lapidary wheel on other side
#6 Jet Drill Mill
#7 Harbor Freight floor mdl. Drill Press
#8 Small Harbor freight Drill Press in leather room
#9 Bridgeport Mill
#10 Atlas 6" metal lathe
#11 Another Atlas 6" metal lathe
#12 Baldor Buffrer
#13 Home made buffing lathe(holds 4 Buffinh wheels
#15 Small Harbor freight Metal lathe
#16 Pantigraph Engraver
#17 Chop Saw
#18 Bandsaw
#19 foredom flex shaft
#20 Compresser
and finally a 5000 watt generater incas the wife turns the Christmas Lights On
And She Knows about all of them
I think this is most of them:
Bader BIII
6X48 Grinder
6X48 Grinder
4X36 Grinder
9”Disc Grinder
9” Disc Grinder
12” Disc Grinder
Sharpening Grinder
Forge Blower
Forge Blower
Forge Blower
Air Compressor
Welder
2 Generators
Roof vent fan - Grinding Shop
Floor stand fan
Hanging fan
10” Buffer
6” Buffer
6” Buffer
Sharpening Wheel
12” Grinding Wheels
8” Bench Grinder
6” Bench Grinder
Lapidary wet grinder
8” Diamond Saw
Diamond Wire Saw
Drill Press
7X12 Metal Band Saw
6X8 Metal Band Saw
Counter -top Metal Band Saw
12” Wood Band saw
Stationary Table Saw
Portable Table saw
Metal Cutoff Saw
Compound Miter Saw
6” Jointer
4” Jointer
4” Handheld Belt Sander
3HP Router/shaper
Standard Router
Shop Fan
Roof Vent fan - Wood shop
Angle Grinder
Radial Arm Saw
Lathe Tool Sharpener
Well Pump
Vacuum System
Shop Vac
Leaf Blower (to blow out smithy)
Air shield (Breathing System)
Outside Air Umbilical System
3 Extra AC Motors on the Shelf
Spare 1.5HP DC Variable Speed Setup
Inside Shop has :
4 flex shaft units
Faceting Machine
Engraver Sharpener
Woodhog
Air Brush Compressor
Consew Industrial Sewing Machine
1X12 grinder
Micro-motor Die Grinder
Die Grinder
Dust Collector
Shop Vac
Stacy
Bader BIII
6X48 Grinder
6X48 Grinder
4X36 Grinder
9”Disc Grinder
9” Disc Grinder
12” Disc Grinder
Sharpening Grinder
Forge Blower
Forge Blower
Forge Blower
Air Compressor
Welder
2 Generators
Floor stand fan
Hanging fan
10” Buffer
6” Buffer
6” Buffer
Sharpening Wheel
12” Grinding Wheels
8” Bench Grinder
6” Bench Grinder
8” Diamond Saw
Diamond Wire Saw
Drill Press
7X12 Metal Band Saw
6X8 Metal Band Saw
12” Wood Band saw
Portable Table saw
Metal Cutoff Saw
Compound Miter Saw
6” Jointer
4” Jointer
3HP Router/shaper
Standard Router
Shop Fan
Angle Grinder
Radial Arm Saw
Well Pump
Vacuum System
Shop Vac
Inside Shop has :
4 flex shaft units
Faceting Machine
Engraver Sharpener
Woodhog
1X12 grinder
Die Grinder
Dust Collector
Shop Vac
Stacy
Stacy,
WoW! Did you get a special, thank you card, from your local utility company? :D
The funny thing is, you can always justify, one more, if you give it some thought. I know I can!
Have a nice holiday, Fred
Drill Press
Bader BIII
1X42 Delta belt/disc combo
10" table saw
Miter saw
very old dual shaft motor that gets used as a buffer/wire wheel
very old dual shaft motor that gets used as a bench grinder
shop vac
Not much for motors really, but quite a bit compared to when I first started gathering tools and equipment. About all I had for tools in 2000 was a tape measure and a cordless screwdriver!
Another amazing thing to think about is how much money you have tied up in your shop/garage/household tools and equipment! It sure would cost a bunch to replace it all! -Matt-
Dang, reading Stacy's well-considered list, it's surprising how many items like the fans, powered respirator, shop-refrigerator compressor, etc, can go overlooked in a casual inventory. We take the powered appliances so for granted that they go unnoticed. Even this computer has three electric motors what with a fan, disc drive and hard drive, as does my toothbrush.....
What a remarkably wired world! Just the resistance in the wires must be contributing somehow to global warming! :)
Anybody remember the Will Ferrell SNL skit about the TV announcer going feral when the power went out?
Better include a good set of Nicholsons in our bug-out bags. :D
If I turned them all at one time, I would be in deep kim-chee. I was intrigued by this post, and was somewhat surprised (OK, not really) by the amount of redundancy in my shops. As Fred said, you always seem to be able to justify one more or one bigger. I have pretty much reached the max needed in my setup........... But when I move to my retirement shop and go full time.... Oh Boy!!! I may well have 440 three phase pulled in.
Or I may order some uranium and build my own reactor.
