Does this attachment fit on the Bk2 sheath?
hi, I want to get a bk2 from amazon found here- http://www.amazon.com/Ka-Bar-Becker-BK2-Campanion-Fixed/dp/B001N1DPDE
Now, there is a pouch attachment that you can put on a BK2 sheath. A video of this can be found here- http://www.youtube.com/watch?v=tuygWw2gUOI
The guy in the video has a link to the pouch in the description but he says it's a "different link" because the other one wouldn't work. Here is the link to that pouch anyway- http://www.knife-depot.com/knife-322308.html
On the link for the attachment pouch, it says that it fits on the ESEE-5 or ESEE-6 hard sheaths. Is this the sheath that comes with the BK2 from amazon? If its not the same sheath, does the pouch fit on the BK2 sheath anyway? If it doesn't fit, where can I find a sheath for the BK2 that is compatible with some kind of pouch attachment. I want this attachment so I can make a "knife survival kit".
Basically I want a very similar set-up as to what the guy in the video has.
Didn't look at the video but I make a sheath that mounts a pouch to the BK2. You can also use the ESEE Molle Back with this setup too but I don't like mounting the pouch up high since the scales are so thick on the Beckers.... so I mount it at the bottom of the sheath instead like my original "Pouch-Sheath" designs.
Here's some examples of my Pouch-Sheaths.
I put them on other sheaths too:
I don't have a stock sheath to check but I've seen some where guys have mounted pouches directly to them... maybe just drill some extra holes or use paracord? One thing I didn't like is how floppy the belt attachment is on the stock sheath and the retention is off the charts.
Hope this helps.
Eli
