- May 30, 2002
WW2 16,5 inch
Used it to chop some trees in the forest.
Came home with it full of sap.
Tried to scrub it clean under running water. Tried soap and sponge. Didn't work.
Found a bottle of something in the closet. The label said:
"Bathroom & shower
Efficient and mild"
Sprayed that on the entire blade.
Suddenly noticing strong burning smell from that stuff. Kind of stinging in my nose. Bad I thought, very bad.
Looking at the blade in front of me as it started shifting colour or something. Looked as if rust formed with hyperspeed.
Small amount of panic.
Put under spring in lots of hot water. Scrubbing scrubbing scrubbing.
Now I have a blade that looks as if someone left it all full of blood and left it drying up for about a year. Not red, but rusty brown. It really looks as if the blade has been dipped in some kind of liquid and massive drops have been running down on it to form tracks.
Oh, and the hardening of the edge shows now. I can see that it stops before the point and the bend. The hardening is exactly 0,9 mm deep into the edge.
I am a little bit clueless about the temperature regimes during heat treatment. Did I destroy or change the properties of the blade by holding it for a considerable time under hot water? The entire blade felt hot afterwards, somewhat hotter than the edge usually becomes during chopping trees. But since I can still see the hardening then it must still be there, or what? Or could the hardness on the edge now be lesser than before or something?
Can I undo the new bloodrusty colouration pattern?
It says on the bottle of cleaning agent that it contains less than 5% anionic tenside. Should not be used on "marmor" which is that natural rock that the ancient Greeks used a lot. It doesn't say anything more about the chemical compounds.
"Bathroom & shower
Efficient and mild"
