IIRC, a scandi grind is a sabre grind without a secondary bevel. If so, couldn't you just resharpen to remove the secondary bevel creating a scandi grind?
In most profile illustrations I've seen, the scandi grind looks like a low sabre grind while non-flat Beckers have high sabre grinds.
With the blade thickness of most the BK's, would a scandi grind be beneficial?
A Scandi is real nice on a blade of relatively thin stock and you'd struggle to find a Beckerhead that hasn't owned a Mora, in my experience the main benefit is to put more meat behind the edge of a relatively thin blade (this is one reason why Moras et. al. can get by with the hard use that we all see on the web). It's my opinion that we don't really *need* this here in Beckerland because we are blessed with copious blade thickness. A lot of others purport it for ease of sharpening, which it has-- only one angle to follow, no secondary bevel to accidentally blend into your primary bevel. And my hand can feel a different feedback when it works wood.
Many Beckerheads, myself included prefer a convex bevel (or even a full convex grind). For my use, I prefer the lower drag at the eased shoulder, it glides right through the media. In the words of someone I listen intently to on such matters, "A straight razor is just about the only thing I wouldn't put a convex on." And, believe me, Uncle Ethan has tried out any blade he can sneak off to a brushpile or treeline with to constantly reevaluate what he does, and why he does it that way-- he's a user of edged tools.
For Clarity's sake, here is a visual (sadly, pilfered from the web) on what the cross sections look like.
[/url]grind angles by ThePointyEnd, on Flickr[/IMG]![]()
As for stock Becker angles, Bladite put together a handy section in the blade database sticky, linked here:
http://www.bladeforums.com/forums/s...-(Knife-Specs-and-Data)?p=8961759#post8961759
Sorry I haven't found Dubs's renderings as of this post, took long enough to find a decent pic of grind types, haha.
Hope this helps!
One thing though, I was asking about the primary grind angles in my previous post, not the secondary grind (edge angle). IIRC, most scandi knives are somewhere in the 11 degrees per side area. The reason I brought that up, was because I wasn't sure if simply taking a saber ground becker (like the BK17 for instance) and making it a scandi edge would be feasible, or if it would give you too obtuse/fine of an edge angle (let alone thinking about all of the grinding that would be).
Haha, right you are! that's what I get for posting right after work, lol.
Let me find my angle finder. ironic, I know...
Ask, and ye shall receive:
BK-14 approx 4 deg. per side.
BK-15 approx 3 deg. per side.
BK-16 (FFG) approx 3 deg. per side.
BK-16 (sabre ground) approx 7 deg. per side.
BK-17 approx 6 deg. per side.
BK-9 approx 8 deg. per side.
man, I wish there was a degree sign on the keyboard, lol.
All these measurements were taken on my dial type angle finder from a home improvement store, hence they are approximate.
I will not say never but, there are so many blades nearer and dearer to my heart, that I want to see in production, that it is unlikely anytime in the next several years....... It is no secret that I am not a big fan...... I have some and use them from time to time and certainly from a mfg. point of view they are really tempting because of their simplicity and therefore cheapness.....I do understand their appeal and their proponents definitely have a point......... I gotta say tho, that every time I pick one up I want to find a grinder and convex the bejazus out of it....
Ethan
