I know there's a few of you that turn out beautifully reconditioned axe handles and all anyone says is "I just soaked it in BLO", there's got to be more to it. What I'd like to know is how exactly do you go about making an old, dried out handle look like the one in your picture? Do you clean first with solvents? Sand it all down? Can someone walk us less experienced people through the process? I'd be most grateful and I know others would too.
What I do is sand - a bit more than lightly - and then finish. Old handles will soak up a ton of BLO. I apply coats twice a day with a brush at first and then with a cloth once it's soaked up a few coats. On some very old dry handles I've given them as many as 6-8 coats of BLO. On fresher handles 2-4 coats will do. Then I apply 3-4 coats of Tung Oil over the BLO, letting them dry for 12-24 hours depending on temperature and humidity. After the 1st coat of Tung I will sand lightly between coats with wet/dry sandpaper. I don't sand before the final coat. Typical tung treatment is coat, sand, coat, sand, coat, coat.
