- Jun 11, 2006
After building my oven my first question is to the temp accuracy. Wanted to know if I could trust what the display was showing me. So I ordered some temp sticks. I found a good deal on some on Amazon called thermomelt made by markal. I ordered them in 1400°, 1450°, 1480°, 1500° and 1550°. I also got some in the higher range. One reason I'm making this post is to pass out a warning to anyone else that is considering buying this brand. I tried the draw a line and heat but no work. These markers are very hard and don't draw a line. At first I was kinda pissed as I could not get anything to work. I was getting weird results. I then tried just touching the steel in the oven with the stick in the jaw of the tongs. The end of the stick would just crumble like wet sand. So then I tried putting little chunks onto a steel plate and just trying to melt them. No luck even after heating and trying to smear it with another bar of steel. The weird thing was the area around the chunk would look wet but the chunk was still there. Then the other day I got so fed up I called the company and talked to a guy that was sapost to everything. I explained what was happening and he was baffled. I explained the wet look and asked what do these do when that "melt" she said thy can be crumbly. I told him I tried to just melt a chunk in the oven on a bar of steel and it did not melt. He said it should have at least changed shape into a blob. I said nope nothing just a wet spot around it. I said it's like the binder is melting out of the stick and leaving the grains there. He said that's exactly what's happening. And said the grains should melt. He then blew my mind and said did you go hotter? Face palm, I said I went like 50° hotter but nothing. He said go hotter, these markets are guerenteed to +-15°. I said ok I will try that.
I then went to the shop and relazed I might have an issue that I never even considered. I swapped out my TC with a very fine thin wire TC. It measures the temp very fast and keep the oven from over shooting. I reliezed it was still in there. I swapped it out with my massive TC and fired up the oven. I let it equalize at 1480° for one hr. Then I slipped in my bar of steel with 4 chunks of temp stick on it. 1450°, 1480°, 1500° and 1550°.
I had tried this befor but never did anything. My thought was if it was high or low at least one of these would pick it up. I let it sit in the oven for 10° and opened the door and hot damn it worked.
Come to find out my thin Wire TC was way off by 100° or more. This error would not show up Until it got into the higher temps. But this TC plugged into a pid is what put me down this road any way because it would show my oven was much hotter then what the control would say. But it was wrong I guess, never trust cheep Chinese wire TC. But looking at my test the 1450° and 1480° melted perfect and the 1500° and 1550° was untouched. You can see a wet area under them but as was discovered that's just binder. So I'm real happy to know I'm at least within an close range of what the controller says.
So let that be a lesson learned. Just because you think something is wrong does not mean it is. But I would highly recommend if you have an oven to test it. Because of my oven was off by that much with that cheep TC so could yours if something is off. If any of you want to do the same test I would be more then happy to sent you some chunks of my stick so you could do this test.
