In case you haven't seen the announcement on ETS.
http://www.dougritter.com/dr_rsk_mk2.htm
http://www.knifeworks.com/dougritterrskmk2perseverance.aspx
Doug Ritter RSK® Mk2
Design Ethan Becker & Doug Ritter
Blade Material 1095 hardened to 57 HRC
Blade Length 6 in. (15.24 cm)
Blade Thickness 0.188 in. (4.78 mm)
Blade Shape Wide-Chord Drop Point
Blade Grind High Flat Grind
40º inclusive edge, 8º bevel
Overall Length 11.375 in. (28.89 cm)
Balance Variable Perfect Balance
Weight (full up) 13.2 oz. (374 g)
Weight (w/ all 3 brass plugs removed) 12.8 oz. (263 g)
Tang Style Full, extends past handle material at rear, lanyard hole
Blade/Tang Finish Charcoal Gray Powdercoat
Handle Material Black Glass Reinforced Swiss GV6H
Sheath Multi-carry Ballistic Nylon w/ heat molded Liner
What do you think about the adjustable weight?
