Tack said:
Padawan,
The overall specification of the Ritter RSK 1 is pretty good for my needs. This knife appears to be exceptionally well specified blade-wise but the locking mechanism and the handle scales have been criticised elsewhere. This is the
Tack
I ran over my Benchmade 551 with my car a couple of times, to prove a point on another forum. I have seen Griptilian handles go to hell and back and still come back for me. I have 60 or so Benchmade's and have never had a lock failure with the Axis lock. No lock is perfect, yet it is about as good as you are going to get in production knife. Since you are a left hander, the Axis Lock is one of the better choices for you.
Spyderco makes a good knife also, if you find one you like from them, it should serve you well.
My first Griptilian I gave to a friend who is a foreman in a machine shop. He used it everday for almost two years. Aside from clip wear, and the coating wearing off the blade... It still locks up tight, and works well. That was the 440C version... Your S30V should even preform better. Too bad you missed the M2's... I have a Ritter Mini-Grip in M2, and no it is not for sale...
Since you are planning on using the knife hard in a work enviroment, I would invest time understanding the nature and drawbacks of different blade steels. Will it chip? What happens if I cut something and run into a staple? How is it to sharpen? Do I want edge retention or a blade that will bend and not break? Keeping that in mind, remember the basic Griptilian can be had in the following steels: 440C, 154CM, S30V, D2, and M2 (good luck with the last one).
If you like the Ritter Grip, get it... It is a well regarded knife and should serve you well.
