- Jul 5, 2009
There isn't really a format for this overview. I will just mention whatever comes to mind and try to show pictures explaining what I mean.
For some reason, ImageShack decided to rotate many of my images 90 degrees.
I received this knife last Friday and have spent some time using/playing with it.
First, some comparison pictures:
It feels great in the hand; I have large hands and have plenty of room.
Blade centering is perfect
This blade is thick!
The tip of mine is not exposed in the closed position.
You can see where they sanded the tang in order to correct the problem
However, when the blade is closed, the edge is very close to the spine of the knife. I can easily touch the blade just by resting a finger on the spine. I could not really find a good angle to show this. I also have no idea why imageshack made the picture vertical
The texture of the G10 is great. Not too aggressive and not too smooth. It looks cool too
The coating on the blade is sweet. It's very smooth and very durable. I cut through a bunch of treated lumber and you can barely see any wear.
The thumbstuds are HUGE. They grab my pants when trying to clip the knife in.
The clip is alright. It allows the knife to ride as deep as possible in your pocket. It was very weak when I got the knife though. I could easily slide it from side to side across the handle. I took the clip out, bent it, and now it has the perfect tension.
The bottle opener works pretty well. I've heard that it's better than the fixed HEST but I don't have one so I wouldn't know. It does work like a wave. I waved it open on the first try - real easy.
The lockbar is massive and locks at about 50%.
This knife uses nylon washers. Not sure if I like these; I would have preferred a metal/alloy of some kind.
You DO NOT need the skull tool to take down the knife. The pivot accommodates an allen key.
For me, the rotoblock is useless but it does work. When the blade is open, rotating the rotoblock moves the tab shown below into a cutout in the lockbar. This prevents the lockbar from being pushed back over. It also acts as a stop and prevents you from pushing the lockbar over too much when unlocking the blade.
Here is what the rotoblock looks like taken apart:
Here is a better look at the washers. You can't really tell in this picture, but the detent hole is deep and not tapered.
The scales and handle require some messing with but eventually come right off.
You can see how the clip is mounted here:
I could not get a picture of this but the edge grind was pretty off center. One side was ground much more than the other. The two sides are ground at significantly different angles.
This is also my first experience with D2. I love it so far. It sharpens well and has pretty good wear resistance. Really takes a nice edge.
This was my biggest issue with the knife:
When I first received it, the blade was IMPOSSIBLE to open with thumb pressure only. The lockbar just had so much tension pushing the ball into the detent on the blade. Eventually I took the knife apart and bent the lock bar out (you have to remove the rotoblock to do this). I wound up pushing the bar over too much and the result was a VERY sloppy lock up. I could wiggle the blade up and down and hear the clicking noise of the tang hitting the lockbar face, though the lock never failed. I lived with this for a day until I took the knife apart again so I could bend the lockbar back over. This worked somewhat as there is significantly less up and down play. There is still a very small amount though. I will have to take the knife apart and try bending it over a little bit more.
Overall, once the kinks are worked, the HEST folder is truly a hard-use, tough little knife. :thumbup:
If you have specific questions or want to see a specific picture, I'd be happy to help.
