DragonFly Clip WAY too tight
Folks
any suggestions on bending out/losening the clip
New today
Cliping on waistband of dress slacks is a two hand job
Struggle to get on a 1.5 inch belt
thanx in advance
bw
Which Dragonfly? The metal clips on the all stainless and G-10 ones should respond well to gentle and judicious lifting with your finger. The molded clip on the FRN version is more problematic to adjust, but generally not over tight. All are intended as pocket clips, waistbands and belts do tend to be thicker.
Paul
My Personal Website ---- Beginners Guide to Spyderco Collecting ---- Kiwimania ---- Spydiewiki
Dead horses beaten, sacred cows tipped, chimeras hunted when time permits.
WTC # 1458 - 1504 - 1508 - Never Forget, Never Forgive!
It's easy to grin when your ship comes in and good fortune and fame are your lot, but the man worthwhile is the man who can smile with his shorts twisted up in a knot. - Morey Amsterdam
Per the factory:
Pull the clip
hold with padded pliers on the attachement point
bent up
re install
test
repeat if nessasary
over
I usually let the Dfly rest in the pocket. Perfect size for that, I don't want to risk losing it by clipping it.
Start out using it as a money clip. Put 1-2 bills in it the first day or two. Work it up to 10 bills or so, then try the waistband or pocket.
Per the factory:
Pull the clip
bent up
re install
test
repeat if nessasary
over
Seems to me like a more complicated way to achieve the same thing just lifting up on the end of the clip would, but whatever works for you, works for you. :)
Paul
Paul
I tried just bending it up
No Joy
This particular batch of spring clips REALLY dont want to give up
Waiting for my Chris Reeves lube and some time this weekend
to lube, round the sharp bits and loosen the clip
