Draw files?
I did a google search for draw files, hoping i would find a good place to buy one....Anyone have a link where i can get some? Looking to get a few different sizes...
Thanks
Mike
Draw filing is more a technique than a specific file Mike. Instead of pushing the file almost parallel to the work you turn it 90 degrees and pull it, like a drawknife.
Draw filing is a technique not a type of file. Pretty much any file could be used that way but a smooth cut works best in my opinion. Once you get the surface in somewhat the shape you want it to be. The file is layed upon the surface and either pushed away from yourself or pulled to yourself. Using only that one direction to further refine the surface shape to what you want!
Draw filing is defined as:
Filing by pushing and pulling a file sideways across the work.
Some of the best files are made by Nicholson, the black diamond are the best that Nicholson puts out.
http://en.wikipedia.org/wiki/File_(tool)
This is an excerpt from that site.
Some of the common shapes and their uses:
Mill files are the most common shape; they are rectangular in cross section and taper slightly in both width and thickness from tang to end. They are all single-cut.[2]
Hand files are parallel in width and tapered in thickness; they are used for general work.
Joint round edge files are parallel in width and thickness, with rounded edges. The flats are safe (no teeth) and cut on the rounded edges only. Used for making joints and hinges.
Half round ring files taper in width and thickness, coming to a point, and are narrower than a standard half round. Used for filing inside of rings.
Barrette files are tapered in width and thickness, coming to a rounded point at the end. Only the flat side is cut, and the other sides are all safe. For doing flat work.
Checkering files are parallel in width and gently tapered in thickness. They have teeth cut in a precise grid pattern, and are used for making serrations and doing checkering work, as on gunstocks.
Crossing files are half round on two sides with one side having a larger radius than the other. Tapered in width and thickness. For filing interior curved surfaces. The double radius makes possible filing at the junction of two curved surfaces or a straight and curved surface.
Crochet files are tapered in width and gradually tapered in thickness, with two flats and radiused edges, cut all around. Used in filing junctions between flat and curved surface, and slots with rounded edges.
Knife files are tapered in width and thickness, but the knife edge has the same thickness the whole length, with the knife edge having an arc to it. Used for slotting or wedging operations.
Pippin files are tapered in width and thickness, generally of a teardrop cross section and having the edge of a knife file. Used for filing the junction of two curved surfaces and making V-shaped slots.
Square files are gradually tapered and cut on all four sides. Used for a wide variety of things.
Triangle files, also called three square files, are gradually tapered and come to a point. Used for many things, cutting angles less than 90 degrees, etc. It has been pointed out that there's no such thing as a "three square". Triangle files are 60 degree angles, and "square" is 90 degrees. All this is true, but triangle files are often called the term simply as a matter of slang.
Round files, also called rat-tail files, are gradually tapered and are used for many tasks that require a round tool, such as enlarging round holes or cutting a scalloped edge.
Round parallel files are similar to round files, except that they do not taper. Shaped like a toothed cylinder.
Equalling files are parallel in width and thickness. Used for filing slots and corners.
Slitting files are parallel in width with a diamond shaped cross section. Thinner than knife files and use for filing slots.
Nut files are fine, precise files in sets of graduated thickness, used by luthiers for dressing the slots at the end of the neck which support the strings of guitars, violins etc., in the correct position.
Pillar files are parallel in width and tapered in thickness for perfectly flat filing. Double cut top and bottom with both sides safe, these are long, narrow files for precision work.
Warding files are parallel in thickness, tapered in width, and thin. Like a hand or flat file that comes to a point on the end. Used for flat work and slotting.
Dreadnought (curved teeth) and millenicut (straight teeth) files both have heavily undercut, sharp but coarse teeth. Both can be used for rapidly removing large quantities of material from thick aluminum alloy, copper or brass. Today, the millenicut and dreadnought have found a new use in removing plastic filler materials such as two-part epoxies or styrenes such as those commonly used in automobile body repairs.
Farrier Rasp files are tanged horse rasps used mainly by horseshoers and blacksmiths. They are flat with rasp cut on one side (upstanding teeth arranged in rows with curved cutting edges of generally pyramidal shape and have a cutting face with a positive rake or slope) and a double cut file on the reverse side.
Ok...i feel rather noobish right now lol. I was under the impression there was a file that the teeth ran from handle to tip...Swear i saw a file in that configuration. I have alot of mill files and such that i can use. Actually, i plan on heading to Sears later...might grab the biggest mill file i can get. Also grabbing some steel to start the jig ideas that Nick has in his WIP thread....awesome :)
I have seen a double tang draw file in photos, but don't know of anyone who sells one currently. Most folks just wrap duct tape on the end of a mill file, and use a file handle on the tang.
When I was taught to draw file it was with a single cut file as it was a finishing operation ! Particular attention should be paid to keep the file very clean with frequent use of a file card !
