Dremmel cutting
Hi guys I bought 1ft of 0-1 from texas knife maker supply. I want to cut it with my dremmel how well it work, will the tiny blades wear out fast. Or should I just use a hack saw, or drill the oultine holes then cut with dremmel. thanks
Warrior24, forgive my ignorance, but is 0-1 stainless. If so, forget the dremel, that stuff eats blades like crazy. If not you might have some luck, but you may be better off with a simple jigsaw with a metal cutting blade. I'm not a knifemaker, but I do cut metal at work often enough to suggest that dremels are best used for details and fine cutting, at least in my experience. We usually use them to widen out the strike plates for door latches.
If it were me, and my only tools were a drill press, a hacksaw, and a dremel. I'd drill and follow it with a hacksaw. That being said, if you plan to use a hacksaw, spend a few $$ and get one of the high-tension hacksaw frames. It will make a WORLD of difference in the ease of your saw cuts.
-d
I'm thinking you will go crazy trying to cut it out with a dremel and go through a lot of the cutting disks. You may want to drill it and cut it with the hack saw. Metal cutting band saw is better if you have access. Is your steel .125" thick?
I have done about 20 blades with my dremel- YES it does eat blades. I have found that expensive blades are not much better than cheaper ones (exception being some fiberglass blades). I did it in both 440C and O1- the O1 is definately easier to cut. An integral hatchet I am making took about 6 hrs. to cut out of 1/4 inch O1. Now I am starting to use the drill and cut method as I wanted to save material but am now more concerned about getting knives out of steel. If your designs are very curved you may drill and then need to use the dremel after but that will be determined by your designs.
In regards to hacksaw blades- At work we have both Bi Metal(18 & 24 tpi) And 18tpi Bi Hard Cobalt- does anybody have suggestions on what would be best on 1/16, 3/32, 1/8 & 1/4 inch steel (mostly O1)
the fiberglass wheels work GREAT, if you have enough of them. I had the unfortunate experience of cutting out a 27" machete from .445" 5160 with my dremel, i think the material wasnt annealed b/c the one hacksaw blade i had(bimetal) it ripped the teeth off after about half an inch
Hello-
I haven't been at it long, but I've cut out about a dozen blades using an inexpensive (around 39 bucks) 4.25 inch angle grinder I bought at Home Cheapo. They have all been either 1/4 or 3/16 1095 or 440c blades. I do the rough cuts with cutoff wheels (the cheapies are about 98 cents apiece). I average 2 cutoff wheels per blade profile. It can't do very tight curves, but if you make relief cuts and make diminishing-angle straight cuts, you can rough in almost any curve, inside or outside. Using this method, I can cut out a 14 in OAL hunting knife in about a 20 minutes.
Then I can pop on a grinding wheel to do a lot of the profiling while it's still clamped to the bench. I can usually get the rough profiling complete enough so that the finish profiling on the belt grinder only takes a few minutes.
It's a pretty fast, inexpensive solution that seems to work okay for me. Eventually, I'll probably move to a plasma cutter or something.
Cheers,
Pat Riley
I will try that and the hacksaw and see which one works better for me. I am still waiting to get the 0-1 in the mail.
warrior24, I wore out a Dremel by cutting ats-34 and d-2, but since it was under warranty......
I still use one but I go a LOT slower.
If you grind/cut much metal with a Dremel, you will be replacing it soon. The open casing allows metal dust to get in on the windings and it will short them out.
Offset grinders are much better, being made to cut metal.
You would be better off to use a hacksaw and save the Dremel for other things that won't destroy it.
""In regards to hacksaw blades- At work we have both Bi Metal(18 & 24 tpi) And 18tpi Bi Hard Cobalt- does anybody have suggestions on what would be best on 1/16, 3/32, 1/8 & 1/4 inch steel (mostly O1)""
Does nobody have an opinion on the differences between the two
