Thanks everybody for your compliments! I appreciate them.
Phillip,
That is a nice looking combination of stile and function. Please post process for getting such magnificent contrast in the damascus. ( starting grit of finish and etchant and time of etching and final finish grit...)
Scott Stephens
jScott
I finish the blade by hand to 400 or 600 grit. 600 is best, but 400 is good enough. (Something I've learned the hard way is, make sure you finish the blade to at least 240 grit BEFORE heat treat. If you leave any coarse scratches on the blade, it will show up when you etch it, no matter how fine you polish it after heat treat.)
Then I etch it for about ten minutes, neutralize it, dry it off, then go over it with fresh 1000 grit paper (backed up with a stick) till it's shiny, then etch it again for 10 minutes.
Repeat 3 or 4 times, using dull 1000 grit paper, until you get the depth you want.
I've found some patterns look really good when given a light buffing. Makes them shimmer in the light better.
dlpierson said:
Beautiful Phillip! I gather you didn't have as much trouble finishing the ivory micarta as many of us. What's your secret?
This is the first time I've used the ivory micarta, and I didn't know it was supposed to be difficult, so it went very well.
I just treated it the same as I do all my micarta....
What kind of trouble does it give people?
