Cliff Stamp
BANNED
- Oct 5, 1998
This is a similar test on Dri-Cote as performed on several other products :
http://www.bladeforums.com/ubb/Forum3/HTML/001904.html
I cleaned the blade and it was close to NIB, it had been used a few times, but never seriously and there was no visible rusting including a quick sweep under 10X magnification.
I marked out a section near the tip and applied the spray to the area and made a few passes along the flats and perpendicular to the spine and edge. It goes on clear and coats well. I then did about 250 cuts on light grasses and hay. Next I applied a salt water solution to the blade and left it out overnight.
The next day the blade showed signs of rusting on the front and back and the rust went through the section that had the Dri-Cote applied no differently than any other part of the blade, with a heavy coat of rust running completely along the edge and spine and spots on the flats:
This product was advertized as having many features including being a rust protector and being very wear resistant. It is however mainly something used on wood working tools to make smoother cuts.
-Cliff
[This message has been edited by Cliff Stamp (edited 10-11-2000).]
-Cliff
