Hi Andre , for the 0-80 my Tap Drll Chart lists a #56 drill @ .0465 & when taking into consideration the probable oversize hole the drill will make that drill will give you 74% thread. For all following sizes this is the format I will follow
- 0-80 #56 Drill @ .0465 74% thread
3/64 Drill @ .0469 71% thread 1.20 mm Drill @ .0472 probably around 60 % thread (this is the one I would use 1.25mm Drill @ .0492 (probably a little large for tap drill for thread that size)
- 2-56 #51 Drill @ .067 74% thread
#50 Drill @ .070 63% thread
#49 Drill @ .073 49% thread (you can see how fast thread % drops off with just a little bigger hole 1.7mm Drill @ .0669 % ?? 1.75mm Drill @ .0689 % ?? (This is the one I would use) 1.8mm Drill @ .0709 % ?? (This one will work too)
