- Jun 17, 2006
I've done a small bit of drilling/tapping in my life, but I seem to have met my match here. I want to drill/ tap two 2-56 holes in the frame of a Kershaw Shallot so I can flip the clip over to be left-handed. I chucked a M2 HSS bit in my drill press and had a go at it. I finally had to back off the handle for fear of breaking the bit and it barely made a divot in the steel frame. The cutting fluid started smoking and the bit was just spinning. I tried again with a new bit and got the same result.
What gives? Is this frame heat treated? Do I need some sort of special bit? I thought this was just going to be easy, like hundreds of other times I've drilled a hole in a piece of metal. Any advice would be appreciated.
