Hello people,
I am looking for 2nd opinion about my intended modification. If you think I can screw up good knife, please let me know!
I want to drill detent hole in my speed assisted Kershaw Knockout m390. I am doing this because I want to increase detent. It is ok as it is, but little stronger would be better.
I bought micro cemented carbide drills from ebay for 4$. ( https://www.ebay.com/itm/10pcs-Ceme...-Drill-Bits-0-6-1-5mm-Option-NEW/371863094243 )
I know they are cheap drills. I hope they will finish this one job I have for them.
I will use drill press.
But I'm not sure what rpm speed I should use for drilling.
My plan is to take out detent ball, then assemble back knife with perfectly centered blade. Then I will drill through existing hole in frame-lock into the blade with 54# (1.4 mm). I just want to mark the spot, not drill real hole.
After that, I will take knife apart. I will drill in blade in marked spot with #57 (1.1mm). Required depth is 0.0144 inch (0.365 mm).
After that I will assemble knife back and check how strong detent is. If it is still weak, I may decide to increase detent hole to #56 (1.2 mm).
