I've used this method on D2 at HRC60 so I'm guessing it should work on S90V at HRC61.
Using a Dremel tool and a small ball end carbide bit, hold the bit at about a 45 degree angle and grind out a small divot on each side of the blade where you want the hole to be. If the ball end is equal to or smaller than the desired hole size, keep going until the shaft of the burr hits the edge of the hole. once the two divots meet to form a hole, switch to a tapered solid carbide burr and slowly ease it in to expand the hole to the desired size. The burr will want to walk if you press too hard so you will have to concetrate on holding the tool steady. This process is slow and you will have to pause frequently to let the Dremel tool cool down. Could take up to two hours. I suggest you wear a dust mask, glasses and ear protection. A cold beer to suck on to break the boredom while waiting on the Dremel to cool also helps.
Enjoy!
Jim Arbuckle
ABS JS
